Giriş
If you need to replace the bottom conical burr, follow this guide to access it. The bottom conical burr is essential to having finely ground coffee, and if it is dull or no longer working, it needs to be replaced. For this guide you will need a Torx Security T20 Bit Screwdriver and an extension bit. To access the bottom conical burr, you will need to follow previous guides on replacing the outside metal casing. This guide is simple once you’ve finished the other.
Neye ihtiyacın var
Twist the top plastic container to the left counterclockwise.
Pull upwards to remove.
Grab the edge of the plastic black ring that sits on top of the device and gently pull up to release.
This is the correct position of bearings and springs when the screw and bottom burr are removed.
8 farklı kişi bu kılavuzu tamamladı.
12Kılavuz Yorumları
Step 5. In my machine there are 5 taps im bottom that has to be released with a screwdriver, before outer cap can be liftet up.
Step 9, It is essential to mark the location of black plastic ring in regards to white plastic part with holes AND in regards to ex. white square plastic part before removing part. Othervise you can’t assemble or you could destroy the burrs when you adjust the grinder to very fine grinds
Hi is it possible to remove the top burr? If yes how?
Thanks
Great description of how to remove the bottom burr. Would be even greater if a new burr was available, which it is not.
wow - Appreciate the instructions but…….screw this….$85 for a new whole new Capresso Infinity Conical Grinder….. https://www.amazon.com/gp/product/B0000A...
