Ana içeriğe geç
Capresso Infinity Outside Casing Replacement
Neye ihtiyacın var
  1. Capresso Infinity Outside Casing Replacement, Metal Outside Casing: adım 1, 2 resimden 1. Capresso Infinity Outside Casing Replacement, Metal Outside Casing: adım 1, 2 resimden 2.
    • Twist the top plastic container to the left counterclockwise.
    • Pull upwards to remove.
  2. Capresso Infinity Outside Casing Replacement: adım 2, 3 resimden 1. Capresso Infinity Outside Casing Replacement: adım 2, 3 resimden 2. Capresso Infinity Outside Casing Replacement: adım 2, 3 resimden 3.
    • Twist the top burr to the left counter clockwise.
  3. Capresso Infinity Outside Casing Replacement: adım 3, 2 resimden 1. Capresso Infinity Outside Casing Replacement: adım 3, 2 resimden 2.
    • Flip entire device upside down.
    • Remove two rubber coverings on the back of the device.
  4. Capresso Infinity Outside Casing Replacement: adım 4, 2 resimden 1. Capresso Infinity Outside Casing Replacement: adım 4, 2 resimden 2.
    • Remove four 11.59mm T10 screws.
    • The screws will have small circular washers under them. Put them aside for reassembly.
  5. Capresso Infinity Outside Casing Replacement: adım 5, 3 resimden 1. Capresso Infinity Outside Casing Replacement: adım 5, 3 resimden 2. Capresso Infinity Outside Casing Replacement: adım 5, 3 resimden 3.
    • Lift the metal outside casing off the black base.
    • Flip the outside casing forward so you have access to the inside of it.
  6. Capresso Infinity Outside Casing Replacement: adım 6, 3 resimden 1. Capresso Infinity Outside Casing Replacement: adım 6, 3 resimden 2. Capresso Infinity Outside Casing Replacement: adım 6, 3 resimden 3.
    • Remove one 11.59mm T10 screw.
    • Let the green wire fall, or place somewhere so it doesn't get in the way.
    • There will be a small metal retainer and washer, put them aside for reassembly.
  7. Capresso Infinity Outside Casing Replacement: adım 7, 3 resimden 1. Capresso Infinity Outside Casing Replacement: adım 7, 3 resimden 2. Capresso Infinity Outside Casing Replacement: adım 7, 3 resimden 3.
    • Remove two 11.59mm T10 screws.
  8. Capresso Infinity Outside Casing Replacement: adım 8, 2 resimden 1. Capresso Infinity Outside Casing Replacement: adım 8, 2 resimden 2.
    • Remove the time/on switch by pulling upwards.
Sonuç
Nina Mackin
555 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G1, Leahy Fall 2018 USF Tampa, Team S1-G1, Leahy Fall 2018 üyesi
USFT-LEAHY-F18S1G1
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 1,554
