Ana içeriğe geç
Capresso Infinity Power Cord Replacement
Neye ihtiyacın var
  1. Capresso Infinity Power Cord Replacement, Metal Outside Casing: adım 1, 2 resimden 1. Capresso Infinity Power Cord Replacement, Metal Outside Casing: adım 1, 2 resimden 2.
    • Twist the top plastic container to the left counterclockwise.
    • Pull upwards to remove.
  2. Capresso Infinity Power Cord Replacement: adım 2, 3 resimden 1. Capresso Infinity Power Cord Replacement: adım 2, 3 resimden 2. Capresso Infinity Power Cord Replacement: adım 2, 3 resimden 3.
    • Twist the top burr to the left counter clockwise.
  3. Capresso Infinity Power Cord Replacement: adım 3, 2 resimden 1. Capresso Infinity Power Cord Replacement: adım 3, 2 resimden 2.
    • Flip entire device upside down.
    • Remove two rubber coverings on the back of the device.
  4. Capresso Infinity Power Cord Replacement: adım 4, 2 resimden 1. Capresso Infinity Power Cord Replacement: adım 4, 2 resimden 2.
    • Remove four 11.59mm T10 screws.
    • The screws will have small circular washers under them. Put them aside for reassembly.
  5. Capresso Infinity Power Cord Replacement: adım 5, 3 resimden 1. Capresso Infinity Power Cord Replacement: adım 5, 3 resimden 2. Capresso Infinity Power Cord Replacement: adım 5, 3 resimden 3.
    • Lift the metal outside casing off the black base.
    • Flip the outside casing forward so you have access to the inside of it.
  6. Capresso Infinity Power Cord Replacement: adım 6, 3 resimden 1. Capresso Infinity Power Cord Replacement: adım 6, 3 resimden 2. Capresso Infinity Power Cord Replacement: adım 6, 3 resimden 3.
    • Remove one 11.59mm T10 screw.
    • Let the green wire fall, or place somewhere so it doesn't get in the way.
    • There will be a small metal retainer and washer, put them aside for reassembly.
  7. Capresso Infinity Power Cord Replacement: adım 7, 3 resimden 1. Capresso Infinity Power Cord Replacement: adım 7, 3 resimden 2. Capresso Infinity Power Cord Replacement: adım 7, 3 resimden 3.
    • Remove two 11.59mm T10 screws.
  8. Capresso Infinity Power Cord Replacement: adım 8, 2 resimden 1. Capresso Infinity Power Cord Replacement: adım 8, 2 resimden 2.
    • Remove the time/on switch by pulling upwards.
  9. Capresso Infinity Power Cord Replacement, Power Cord: adım 9, 3 resimden 1. Capresso Infinity Power Cord Replacement, Power Cord: adım 9, 3 resimden 2. Capresso Infinity Power Cord Replacement, Power Cord: adım 9, 3 resimden 3.
    • Remove two 13.60mm T10 screws.
    • A white, flat plastic piece will have come loose. Place this to the side for reassembly.
  10. Capresso Infinity Power Cord Replacement: adım 10, 3 resimden 1. Capresso Infinity Power Cord Replacement: adım 10, 3 resimden 2. Capresso Infinity Power Cord Replacement: adım 10, 3 resimden 3.
    • Using a Flathead screwdriver loosen the two screws connecting the white and black wire to the plastic box.
    • Do not remove the screws from the box, but loosen them enough to disconnect the black and white wire.
  11. Capresso Infinity Power Cord Replacement: adım 11, 3 resimden 1. Capresso Infinity Power Cord Replacement: adım 11, 3 resimden 2. Capresso Infinity Power Cord Replacement: adım 11, 3 resimden 3.
    • Originally attached to the inside of the outer casing, the green wire needs to be fed through the zip tie which keeps it in place.
    • Lift up on the zip tie far enough to create a space to feed the green wire through.
    • Place the zip tie back around the column that you lifted it from.
    • All three wires that comprise the power cord should be detached from the coffee grinder.
  12. Capresso Infinity Power Cord Replacement: adım 12, 3 resimden 1. Capresso Infinity Power Cord Replacement: adım 12, 3 resimden 2. Capresso Infinity Power Cord Replacement: adım 12, 3 resimden 3.
    • Feed the wires through the small hole at the bottom of the coffee grinder where the external power cord is located.
    • Once the power cord is free of the coffee grinder, you are able to put in the new cord.
Sonuç
Elizabeth Roach
233 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G1, Leahy Fall 2018 USF Tampa, Team S1-G1, Leahy Fall 2018 üyesi
USFT-LEAHY-F18S1G1
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 687
