Ana içeriğe geç
Capresso Infinity Timer/On Switch Replacement
Neye ihtiyacın var
  1. Capresso Infinity Timer/On Switch Replacement, Metal Outside Casing: adım 1, 2 resimden 1. Capresso Infinity Timer/On Switch Replacement, Metal Outside Casing: adım 1, 2 resimden 2.
    • Twist the top plastic container to the left counterclockwise.
    • Pull upwards to remove.
  2. Capresso Infinity Timer/On Switch Replacement: adım 2, 3 resimden 1. Capresso Infinity Timer/On Switch Replacement: adım 2, 3 resimden 2. Capresso Infinity Timer/On Switch Replacement: adım 2, 3 resimden 3.
    • Twist the top burr to the left counter clockwise.
  3. Capresso Infinity Timer/On Switch Replacement: adım 3, 2 resimden 1. Capresso Infinity Timer/On Switch Replacement: adım 3, 2 resimden 2.
    • Flip entire device upside down.
    • Remove two rubber coverings on the back of the device.
  4. Capresso Infinity Timer/On Switch Replacement: adım 4, 2 resimden 1. Capresso Infinity Timer/On Switch Replacement: adım 4, 2 resimden 2.
    • Remove four 11.59mm T10 screws.
    • The screws will have small circular washers under them. Put them aside for reassembly.
  5. Capresso Infinity Timer/On Switch Replacement: adım 5, 3 resimden 1. Capresso Infinity Timer/On Switch Replacement: adım 5, 3 resimden 2. Capresso Infinity Timer/On Switch Replacement: adım 5, 3 resimden 3.
    • Lift the metal outside casing off the black base.
    • Flip the outside casing forward so you have access to the inside of it.
  6. Capresso Infinity Timer/On Switch Replacement: adım 6, 3 resimden 1. Capresso Infinity Timer/On Switch Replacement: adım 6, 3 resimden 2. Capresso Infinity Timer/On Switch Replacement: adım 6, 3 resimden 3.
    • Remove one 11.59mm T10 screw.
    • Let the green wire fall, or place somewhere so it doesn't get in the way.
    • There will be a small metal retainer and washer, put them aside for reassembly.
  7. Capresso Infinity Timer/On Switch Replacement: adım 7, 3 resimden 1. Capresso Infinity Timer/On Switch Replacement: adım 7, 3 resimden 2. Capresso Infinity Timer/On Switch Replacement: adım 7, 3 resimden 3.
    • Remove two 11.59mm T10 screws.
  8. Capresso Infinity Timer/On Switch Replacement: adım 8, 2 resimden 1. Capresso Infinity Timer/On Switch Replacement: adım 8, 2 resimden 2.
    • Remove the time/on switch by pulling upwards.
  9. Capresso Infinity Timer/On Switch Replacement, Timer/On Switch: adım 9, 1 resimden 1.
    • Strip the two wires of their black covering connecting them to the black box.
  10. Capresso Infinity Timer/On Switch Replacement: adım 10, 3 resimden 1. Capresso Infinity Timer/On Switch Replacement: adım 10, 3 resimden 2. Capresso Infinity Timer/On Switch Replacement: adım 10, 3 resimden 3.
    • Solder the two cords holding in the blue and white wire in the black timer box.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Melayne Spataro
272 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G1, Leahy Fall 2018 USF Tampa, Team S1-G1, Leahy Fall 2018 üyesi
USFT-LEAHY-F18S1G1
4 Üyeler
5 adet Kılavuz yazıldı
7Kılavuz Yorumları
do you know where I can get a new black timer box?
geclay@hotmail.com - Yanıt
Where can I purchase a timer/on switch?
Rob Gordon - Yanıt
Same question here, where can I buy this part?
Dominic Daigle - Yanıt
Just piling on,has anyone found where to buy the Timer switch?
Chris DiNicolas - Yanıt
Same, looking for part number and/or where to buy the timer dial.
Hans Sorensen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 32
Her zaman: 2,760
