Ana içeriğe geç
Capresso PerfecTea 260 Dial Replacement
Neye ihtiyacın var
  1. Capresso PerfecTea 260 Dial Replacement, Motherboard: adım 1, 1 resimden 1.
    • First, take the base of the device and flip it over.
  2. Capresso PerfecTea 260 Dial Replacement: adım 2, 2 resimden 1. Capresso PerfecTea 260 Dial Replacement: adım 2, 2 resimden 2.
    • Remove the four 12 mm Phillips #2 screws surrounding the base then lift the bottom half of the base to expose the circuit boards inside the device.
  3. Capresso PerfecTea 260 Dial Replacement: adım 3, 1 resimden 1.
    • Remove the two 7.5 mm Phillips #2 screws holding in the motherboard
  4. Capresso PerfecTea 260 Dial Replacement: adım 4, 1 resimden 1.
    • Unplug the wire going into the side of the motherboard
  5. Capresso PerfecTea 260 Dial Replacement: adım 5, 2 resimden 1. Capresso PerfecTea 260 Dial Replacement: adım 5, 2 resimden 2.
    • Use the metal spudger to cut open the rubber covering the latch where it clamps onto the copper tab.
    • Unplug wire at heating element by first using the metal spudger to push the latch in and then pushing it out.
    • Be careful when unplugging the wire as if it is done too forcefully it can damage the connection and make it difficult to connect a new motherboard
  6. Capresso PerfecTea 260 Dial Replacement: adım 6, 1 resimden 1.
    • Lift the motherboard out of the device
  7. Capresso PerfecTea 260 Dial Replacement, Control System: adım 7, 2 resimden 1. Capresso PerfecTea 260 Dial Replacement, Control System: adım 7, 2 resimden 2.
    • Remove the two 7.5mm Phillips #2 screws from the metal frame.
    • Remove the frame from the assembly.
  8. Capresso PerfecTea 260 Dial Replacement: adım 8, 3 resimden 1. Capresso PerfecTea 260 Dial Replacement: adım 8, 3 resimden 2. Capresso PerfecTea 260 Dial Replacement: adım 8, 3 resimden 3.
    • Remove the two 6mm fine thread Phillips #2 screws attaching the small computer chip to the metal frame.
    • Flip over and remove the 7.5 mm fine thread Phillips #2 screw from the back while holding the 5mm nut on the front securely.
  9. Capresso PerfecTea 260 Dial Replacement: adım 9, 3 resimden 1. Capresso PerfecTea 260 Dial Replacement: adım 9, 3 resimden 2. Capresso PerfecTea 260 Dial Replacement: adım 9, 3 resimden 3.
    • Find the cable that attaches the small computer chip to the heating element connections.
    • Use the spudger to cut open the rubber coating on the latch where it clamps onto the copper tab.
    • Insert the metal spudger into the rectangular hole on the latch and push toward the tab (away from the wire) to unbend the tab.
    • Push the latch off the tab with the spudger.
    • The tab will come loose suddenly. Make sure that you apply force in a controlled manner to avoid injuring yourself or damaging the other components.
  10. Capresso PerfecTea 260 Dial Replacement: adım 10, 3 resimden 1. Capresso PerfecTea 260 Dial Replacement: adım 10, 3 resimden 2. Capresso PerfecTea 260 Dial Replacement: adım 10, 3 resimden 3.
    • Identify the two computer chips that connect the two yellow wires to the temperature controls.
    • Remove the four 5 mm Phillips #1 screws.
    • Remove the two computer chips from their places.
    • The two computer chips are held in place by plastic interference pins. Wiggle the board free of these pins to remove.
  11. Capresso PerfecTea 260 Dial Replacement: adım 11, 3 resimden 1. Capresso PerfecTea 260 Dial Replacement: adım 11, 3 resimden 2. Capresso PerfecTea 260 Dial Replacement: adım 11, 3 resimden 3.
    • Find the computer chip over the dial.
    • Remove the three 6mm Phillips #2 screws.
    • Remove the computer chip.
    • Remember the orientation of the computer chip on the dial and which peg goes into which hole.
    • Keep the plastic frame on the bottom of the chip attached.
  12. Capresso PerfecTea 260 Dial Replacement: adım 12, 1 resimden 1.
    • Unplug the four cables on the left side of the chip.
    • Remember which cable goes to which plug.
  13. Capresso PerfecTea 260 Dial Replacement, Dial: adım 13, 3 resimden 1. Capresso PerfecTea 260 Dial Replacement, Dial: adım 13, 3 resimden 2. Capresso PerfecTea 260 Dial Replacement, Dial: adım 13, 3 resimden 3.
    • Remove the two 6 mm Phillips #1 screws from the black dial base plate.
    • 6 mm Phillips #1 screws
    • Remove the black dial base plate, metal spring, LED tube, and the actual dial.
  14. Capresso PerfecTea 260 Dial Replacement: adım 14, 2 resimden 1. Capresso PerfecTea 260 Dial Replacement: adım 14, 2 resimden 2.
    • Remove the three 7.5 mm Phillips #2 screws from the dial collar.
    • 7.5 mm Phillips #2 screws
    • The dial collar will then come away from the base.
Sonuç
Olivia Morgan
101 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 6-17, Maness Spring 2015 Cal Poly, Team 6-17, Maness Spring 2015 üyesi
CPSU-MANESS-S15S6G17
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 174
