Ana içeriğe geç
Capresso Perfectea 260 Control System Replacement
Neye ihtiyacın var
    1. Capresso Perfectea 260 Control System Replacement, Motherboard: adım 1, 1 resimden 1.
      • First, take the base of the device and flip it over.
      FixBot'a Sor
      Yorum Ekle
    2. Capresso Perfectea 260 Control System Replacement: adım 2, 2 resimden 1. Capresso Perfectea 260 Control System Replacement: adım 2, 2 resimden 2.
      • Remove the four 12 mm Phillips #2 screws surrounding the base then lift the bottom half of the base to expose the circuit boards inside the device.
      FixBot'a Sor
      Yorum Ekle
    3. Capresso Perfectea 260 Control System Replacement: adım 3, 1 resimden 1.
      • Remove the two 7.5 mm Phillips #2 screws holding in the motherboard
      FixBot'a Sor
      Yorum Ekle
    4. Capresso Perfectea 260 Control System Replacement: adım 4, 1 resimden 1.
      • Unplug the wire going into the side of the motherboard
      FixBot'a Sor
      Yorum Ekle
    5. Capresso Perfectea 260 Control System Replacement: adım 5, 2 resimden 1. Capresso Perfectea 260 Control System Replacement: adım 5, 2 resimden 2.
      • Use the metal spudger to cut open the rubber covering the latch where it clamps onto the copper tab.
      • Unplug wire at heating element by first using the metal spudger to push the latch in and then pushing it out.
      • Be careful when unplugging the wire as if it is done too forcefully it can damage the connection and make it difficult to connect a new motherboard
      FixBot'a Sor
      Yorum Ekle
    6. Capresso Perfectea 260 Control System Replacement: adım 6, 1 resimden 1.
      • Lift the motherboard out of the device
      FixBot'a Sor
      Yorum Ekle
    1. Capresso Perfectea 260 Control System Replacement, Control System: adım 7, 2 resimden 1. Capresso Perfectea 260 Control System Replacement, Control System: adım 7, 2 resimden 2.
      • Remove the two 7.5mm Phillips #2 screws from the metal frame.
      • Remove the frame from the assembly.
      FixBot'a Sor
      Yorum Ekle
    2. Capresso Perfectea 260 Control System Replacement: adım 8, 3 resimden 1. Capresso Perfectea 260 Control System Replacement: adım 8, 3 resimden 2. Capresso Perfectea 260 Control System Replacement: adım 8, 3 resimden 3.
      • Remove the two 6mm fine thread Phillips #2 screws attaching the small computer chip to the metal frame.
      • Flip over and remove the 7.5 mm fine thread Phillips #2 screw from the back while holding the 5mm nut on the front securely.
      FixBot'a Sor
      Yorum Ekle
    3. Capresso Perfectea 260 Control System Replacement: adım 9, 3 resimden 1. Capresso Perfectea 260 Control System Replacement: adım 9, 3 resimden 2. Capresso Perfectea 260 Control System Replacement: adım 9, 3 resimden 3.
      • Find the cable that attaches the small computer chip to the heating element connections.
      • Use the spudger to cut open the rubber coating on the latch where it clamps onto the copper tab.
      • Insert the metal spudger into the rectangular hole on the latch and push toward the tab (away from the wire) to unbend the tab.
      • Push the latch off the tab with the spudger.
      • The tab will come loose suddenly. Make sure that you apply force in a controlled manner to avoid injuring yourself or damaging the other components.
      FixBot'a Sor
      Yorum Ekle
    4. Capresso Perfectea 260 Control System Replacement: adım 10, 3 resimden 1. Capresso Perfectea 260 Control System Replacement: adım 10, 3 resimden 2. Capresso Perfectea 260 Control System Replacement: adım 10, 3 resimden 3.
      • Identify the two computer chips that connect the two yellow wires to the temperature controls.
      • Remove the four 5 mm Phillips #1 screws.
      • Remove the two computer chips from their places.
      • The two computer chips are held in place by plastic interference pins. Wiggle the board free of these pins to remove.
      FixBot'a Sor
      Yorum Ekle
    5. Capresso Perfectea 260 Control System Replacement: adım 11, 3 resimden 1. Capresso Perfectea 260 Control System Replacement: adım 11, 3 resimden 2. Capresso Perfectea 260 Control System Replacement: adım 11, 3 resimden 3.
      • Find the computer chip over the dial.
      • Remove the three 6mm Phillips #2 screws.
      • Remove the computer chip.
      • Remember the orientation of the computer chip on the dial and which peg goes into which hole.
      • Keep the plastic frame on the bottom of the chip attached.
      FixBot'a Sor
      Yorum Ekle
    6. Capresso Perfectea 260 Control System Replacement: adım 12, 1 resimden 1.
      • Unplug the four cables on the left side of the chip.
      • Remember which cable goes to which plug.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kenji Anzai
594 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-17, Maness Spring 2015 Cal Poly, Team 6-17, Maness Spring 2015 üyesi
CPSU-MANESS-S15S6G17
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 42
Her zaman: 2,918
