Ana içeriğe geç
Capresso Perfectea 260 Motherboard Replacement
Neye ihtiyacın var
  1. Capresso Perfectea 260 Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • First, take the base of the device and flip it over.
  2. Capresso Perfectea 260 Motherboard Replacement: adım 2, 2 resimden 1. Capresso Perfectea 260 Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove the four 12 mm Phillips #2 screws surrounding the base then lift the bottom half of the base to expose the circuit boards inside the device.
  3. Capresso Perfectea 260 Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the two 7.5 mm Phillips #2 screws holding in the motherboard
  4. Capresso Perfectea 260 Motherboard Replacement: adım 4, 1 resimden 1.
    • Unplug the wire going into the side of the motherboard
  5. Capresso Perfectea 260 Motherboard Replacement: adım 5, 2 resimden 1. Capresso Perfectea 260 Motherboard Replacement: adım 5, 2 resimden 2.
    • Use the metal spudger to cut open the rubber covering the latch where it clamps onto the copper tab.
    • Unplug wire at heating element by first using the metal spudger to push the latch in and then pushing it out.
    • Be careful when unplugging the wire as if it is done too forcefully it can damage the connection and make it difficult to connect a new motherboard
  6. Capresso Perfectea 260 Motherboard Replacement: adım 6, 1 resimden 1.
    • Lift the motherboard out of the device
Sonuç
Rohin Chander
101 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 6-17, Maness Spring 2015 Cal Poly, Team 6-17, Maness Spring 2015 üyesi
CPSU-MANESS-S15S6G17
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 232
