Ana içeriğe geç
Car Seat Belt Stopper Replacement
Neye ihtiyacın var
  1. Car Seat Belt Stopper Replacement, Car Seat Belt Stopper: adım 1, 1 resimden 1.
    • Use a cloth to wipe away any debris from the area.
    FixBot'a Sor
    Yorum Ekle
  2. Car Seat Belt Stopper Replacement: adım 2, 1 resimden 1.
    • Find the existing hole for the seat belt stopper or choose a different location that is better for you.
    • Separate the replacement stopper if it has come assembled.
    FixBot'a Sor
    Yorum Ekle
  3. Car Seat Belt Stopper Replacement: adım 3, 1 resimden 1.
    • Before you begin, make sure that the seat belt buckle is pushed above the hole where you are installing the new seat belt stopper.
    • Push the side of the seat belt button with the needle or point into your desired location.
    • It may require a small amount of force.
    FixBot'a Sor
    Yorum Ekle
  4. Car Seat Belt Stopper Replacement: adım 4, 1 resimden 1.
    • Take the other half of button stopper and slide it onto the pin on the other side of the belt.
    • Fasten the two parts of the button together and squeeze for a secure fit.
    • You may hear a "snap" or "click" when they are fastened together.
    FixBot'a Sor
    Yorum Ekle
  5. Car Seat Belt Stopper Replacement: adım 5, 1 resimden 1.
    • Check the position of the replacement stopper for a comfortable fit.
    FixBot'a Sor
    Yorum Ekle
  6. Car Seat Belt Stopper Replacement: adım 6, 1 resimden 1.
    • Now you can use the seat belt buckle without it falling down!
    FixBot'a Sor
    Yorum Ekle
Sonuç
Changing your positioning of replacement can be used to your liking.
Bir başkası bu kılavuzu tamamladı.
Zhong Chu
137 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 4-1, Whithaus Spring 2024 UC Davis, Team 4-1, Whithaus Spring 2024 üyesi
UCD-WHITHAUS-S24S4G1
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 36
Son 30 gün: 160
Her zaman: 3,078
