Ana içeriğe geç
Carburetor Cleaning
Neye ihtiyacın var
  1. Carburetor Cleaning, Air Filter: adım 1, 3 resimden 1. Carburetor Cleaning, Air Filter: adım 1, 3 resimden 2. Carburetor Cleaning, Air Filter: adım 1, 3 resimden 3.
    • Before starting, ensure that the engine is not running and is not hot.
    • Pull the tab until the filter cover opens. Remove the filter cover.
    • Note that the bottom of the cover is hinged.
  2. Carburetor Cleaning: adım 2, 1 resimden 1.
    • Remove the air filter.
    • The air filter will be either an oily sponge, or an accordion-folded fabric.
    • Note that the air filter is saturated with oil. Wear gloves and use paper towels to avoid creating a mess.
  3. Carburetor Cleaning, Carburetor Cleaning: adım 3, 3 resimden 1. Carburetor Cleaning, Carburetor Cleaning: adım 3, 3 resimden 2. Carburetor Cleaning, Carburetor Cleaning: adım 3, 3 resimden 3.
    • Locate the four bolts holding the air filter housing to the engine. Remove these bolts using the ratchet driver and the appropriately sized socket.
    • Remove the 1/4" bolts.
    • Remove the 5/16" bolts.
  4. Carburetor Cleaning: adım 4, 2 resimden 1. Carburetor Cleaning: adım 4, 2 resimden 2.
    • Lift away the air filter housing.
    • Note that the housing is still attached to the engine via a bendable plastic rod.
  5. Carburetor Cleaning: adım 5, 1 resimden 1.
    • Spray carburetor cleaner into the open carburetor.
    • You may want to wear gloves for this step, as carburetor cleaner is harmful if applied to the skin.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ethan Narad
529 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S25-G15, Maness Spring 2018 Cal Poly, Team S25-G15, Maness Spring 2018 üyesi
CPSU-MANESS-S18S25G15
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 29
Her zaman: 1,698
