Ana içeriğe geç
Cardinal Health Vela Ventilator Exhalation Valve Body Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
Öne Çıkan Belge
  1. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement, Exhalation Valve Body: adım 1, 1 resimden 1.
    • Use a screwdriver to remove the two Phillips #0 screws at the top of the plug guard.
    • Remove the plug guard and unplug the ventilator.
  2. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: adım 3, 1 resimden 1.
    • Remove the four Phillips #0 screws on the back side of the ventilator.
  3. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: adım 4, 1 resimden 1.
    • Remove all six small side panel screws along the bottom of each side of the top cover with the same screwdriver.
    • Slide the top cover towards the back side of the ventilator to remove it.
  4. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: adım 6, 1 resimden 1.
    • Use your Phillips #0 screwdriver to unscrew the four Phillips screws positioned on each side of the battery tray.
    • Lift the battery tray out of the ventilator.
    • Caution: The wires connecting the batteries to the ventilator will still be connected so lift the battery tray carefully.
  5. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: adım 8, 1 resimden 1.
    • Disconnect the batteries from the ventilator by pulling apart the Battery Connector.
  6. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: adım 9, 1 resimden 1.
    • Remove the two Phillips countersink screws from the right side of the rear panel.
  7. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: adım 10, 1 resimden 1.
    • Remove the single Phillips countersink screw in the upper front of the right panel.
  8. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: adım 11, 1 resimden 1.
    • Remove the single Phillips screw in the lower center of the right panel.
  9. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: adım 12, 1 resimden 1.
    • Gently lift out the panel and the power PCB. Lay the panel flat and make the following disconnections:
    • Remove the 2 Phillips countersink screws at the rear of the left panel.
    • Remove the 1 Phillips countersink screw in the upper front of the left panel.
    • Lift out the left panel.
    • Disconnect the following from the main PCB:
    • JP2 40-pin ribbon cable to JP1 on the SVGA out PCB
    • J301 12-pin to J301 on the blender PCB
  10. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: adım 15, 1 resimden 1.
    • Disconnect the green oxygen nebulizer tube
    • Remove the 2 Phillips pan-head screws behind the front panel at the lower left and right.
    • Disconnect the 1/8” silicone tube #4 from P2 on the exhalation differential transducer.
    • Disconnect the 1/8” silicone tube #5 from P1 on the exhalation differential transducer.
    • Disconnect the 1/8” silicone tube #1 from the turbine.
    • Disconnect the 1/16” silicone tube from the front ports of the turbine outlet auto-zero solenoid that goes to the main tubing harness.
    • Disconnect the 1/16” silicone tube from the turbine inlet auto-zero solenoid that goes to the turbine.
    • Disconnect the 1/16” silicone tube from the airway pressure auto-zero solenoid that goes to the exhalation valve receptacle.
  11. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: adım 17, 1 resimden 1.
    • Disconnect the following from the FIO2 monitoring PCB:
    • J2 2-pin (clear conn.) to oxygen sensor
    • J3 2-pin (blue conn.) to oxygen inlet solenoid on blender assembly
    • J4 2-pin (red conn.) to nebulizer solenoid assembly on upper rear of blender
  12. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: adım 19, 1 resimden 1.
    • Remove two Phillips pan-head screws on the valve cover.
    • Lift out the exhalation valve assembly.
Sonuç
Ethan Nikcevich
649 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S11-G22, Paton Spring 2020 Cal Poly, Team S11-G22, Paton Spring 2020 üyesi
CPSU-PATON-S20S11G22
2 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 287
