Giriş
The left panel is structurally significant to the ventilator but is not fixed to any other components. Therefore it is necessary to remove the left panel for a vast majority of service to be done on internal components of the ventilator. You will need a Phillips screwdriver to complete this guide. This part is strictly structural, however it needs to be removed to access many of the parts inside.
Neye ihtiyacın var
Adım 1 Cardinal Health Vela Ventilator Power Cable Removal
Dikkatli ol: adımlar 1-2 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
Use a screwdriver to remove the two Phillips pan-head screws at the top of the plug guard.
Remove the four Phillips #0 screws on the back side of the ventilator.
Adım 6 Cardinal Health Vela Ventilator Battery Tray Removal
Dikkatli ol: adımlar 6-8 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
Use your Phillips screwdriver to unscrew the 4 Phillips pan head screws positioned on each side of the battery tray.
