Giriş
The Turbine is integral to the Ventilator's function. A possible cause of failure during the delivered volume test is the turbine assembly itself. In this case the Turbine assembly must be removed, and either replaced with P/N 16349 or sent to manufacturer for Re-Characterization. This guide will walk through the necessary steps to remove the turbine assembly.
Neye ihtiyacın var
Adım 1 Cardinal Health Vela Ventilator Power Cable Removal
Dikkatli ol: adımlar 1-2 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
Use a screwdriver to remove the two Phillips pan-head screws at the top of the plug guard.
Remove the four Phillips #0 screws on the back side of the ventilator.
Adım 6 Cardinal Health Vela Ventilator Battery Tray Removal
Dikkatli ol: adımlar 6-8 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
Use your Phillips screwdriver to unscrew the 4 Phillips pan head screws positioned on each side of the battery tray.
Adım 13 Blender Assembly P/N 16358A
Dikkatli ol: adımlar 13-21 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
If the rear panel is installed, remove the high and low pressure oxygen fittings from the rear panel using your 3/4" wrench. NOTE: the high pressure fitting is located above the low pressure fitting
Disconnect the main wire harness connector at P2 on the Turbine Driver PCBA
Bir başkası bu kılavuzu tamamladı.
