Ana içeriğe geç
Carlo Robelli CBW-4134CR Piezo Pickup Replacement
Neye ihtiyacın var
  1. Carlo Robelli CBW-4134CR Piezo Pickup Replacement, Piezo Pickup: adım 1, 3 resimden 1. Carlo Robelli CBW-4134CR Piezo Pickup Replacement, Piezo Pickup: adım 1, 3 resimden 2. Carlo Robelli CBW-4134CR Piezo Pickup Replacement, Piezo Pickup: adım 1, 3 resimden 3.
    • Unwind the low E guitar tuner with a guitar winder to loosen the string.
    • Cut the string above the sound hole using a string cutter.
  2. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 2, 3 resimden 1. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 2, 3 resimden 2. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 2, 3 resimden 3.
    • Remove the low E string from the guitar tuner and remove the bridge pin.
  3. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 3, 3 resimden 1. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 3, 3 resimden 2. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 3, 3 resimden 3.
    • Repeat Steps 1 and 2 for the rest of the guitar strings, removing all the pins and strings.
    • Remove the bridge saddle.
  4. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 4, 3 resimden 1. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 4, 3 resimden 2. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 4, 3 resimden 3.
    • Find the preamp box inside the guitar soundhole and disconnect the piezo pickup only.
  5. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 5, 3 resimden 1. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 5, 3 resimden 2. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 5, 3 resimden 3.
    • Inside the guitar, find the piezo pickup and push outward.
    • Once the pickup is sticking out, pull to remove it.
  6. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 6, 3 resimden 1. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 6, 3 resimden 2. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 6, 3 resimden 3.
    • Grab the new piezo pickup and insert it in the designated hole, pressing firmly and ensuring it is neatly tucked in.
  7. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 7, 3 resimden 1. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 7, 3 resimden 2. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 7, 3 resimden 3.
    • Once the piezo pickup is inside the guitar, connect the pickup to its proper input inside the guitar preamp.
  8. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 8, 3 resimden 1. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 8, 3 resimden 2. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 8, 3 resimden 3.
    • Place the bridge saddle back in place.
    • Insert a new set of strings with guitar pins to ensure that the line is not pulled out when winding the new guitar strings.
  9. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 9, 3 resimden 1. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 9, 3 resimden 2. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 9, 3 resimden 3.
    • Once all new strings are wound up, cut off the excess line for a neater look.
  10. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: adım 10, 1 resimden 1.
    • This is how the bridge should look once everything is back into place.
Sonuç
Having a new piezo pickup will heavily improve the sound quality sent from your guitar to the guitar amplifier, recording interface, PA system, or headphones.
Bryant Castor
181 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 288
