Ana içeriğe geç
Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement
Neye ihtiyacın var
  1. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement, Axle Replacement Guide: adım 1, 1 resimden 1.
    • Flip the car with the bottom side facing up.
    • Using a Philips screwdriver, remove the middle screw on the front axle while holding it the axle in place.
    • Carefully place the screw in a magnetic pad (or somewhere you won’t loose)
  2. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement: adım 2, 1 resimden 1.
    • Place the new axle where on the curved side is pointed towards center.
    • Screw it into place but make sure it isn't too tight. The axle needs to able to move a bit.
  3. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement: adım 3, 1 resimden 1.
    • Repeat the same steps for the back axle of the car but without concern of the curved part.
  4. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement: adım 4, 1 resimden 1.
    • Place the new wheel into the car and attach the new screw
Sonuç
Kimberly Santos
331 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G5, Cannon Fall 2017 USF Tampa, Team S3-G5, Cannon Fall 2017 üyesi
USFT-CANNON-F17S3G5
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 841
