Ana içeriğe geç
Casdon Dyson Ball Air Cylinder Motor Replacement
Neye ihtiyacın var
  1. Casdon Dyson Ball Air Cylinder Motor Replacement, Battery: adım 1, 1 resimden 1.
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball Air Cylinder Motor Replacement: adım 2, 1 resimden 1.
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Casdon Dyson Ball Air Cylinder Motor Replacement, Casdon Dyson Ball Disassembly: adım 3, 1 resimden 1.
    • Remove all seven 9.2mm (0.32 in) screws on the back of the vacuum.
  4. Casdon Dyson Ball Air Cylinder Motor Replacement: adım 4, 1 resimden 1.
    • Remove the front side covers by pulling them away from the vacuum.
  5. Casdon Dyson Ball Air Cylinder Motor Replacement: adım 5, 1 resimden 1.
    • Separate the battery compartment from the ball and bead cylinder by sliding the vacuum ball away from the battery compartment.
  6. Casdon Dyson Ball Air Cylinder Motor Replacement: adım 6, 1 resimden 1.
    • Separate the bead cylinder and the fan compartment by pulling the bead cylinder away from the fan compartment.
  7. Casdon Dyson Ball Air Cylinder Motor Replacement: adım 7, 1 resimden 1.
    • Remove beads from the container.
  8. Casdon Dyson Ball Air Cylinder Motor Replacement, Air Cylinder Motor: adım 8, 1 resimden 1.
    • Remove four 9.2mm (0.32 in) screws on bottom of air cylinder motor mount using the PH00 screwdriver.
  9. Casdon Dyson Ball Air Cylinder Motor Replacement: adım 9, 1 resimden 1.
    • Remove one 11.5mm (0.45 in) screw in battery compartment using the PH00 screwdriver.
  10. Casdon Dyson Ball Air Cylinder Motor Replacement: adım 10, 1 resimden 1.
    • Remove the red fan from the motor by pulling the red fan away from the bead cylinder motor compartment.
  11. Casdon Dyson Ball Air Cylinder Motor Replacement: adım 11, 1 resimden 1.
    • Cut wires connected to faulty motor using a set of wire cutters.
  12. Casdon Dyson Ball Air Cylinder Motor Replacement: adım 12, 2 resimden 1. Casdon Dyson Ball Air Cylinder Motor Replacement: adım 12, 2 resimden 2.
    • Remove and replace faulty air cylinder motor.
    • Solder new air cylinder motor's wires to the vacuum's wires which were previously cut.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Seldon Price
612 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G5, Harley Fall 2017 IUPUI, Team S3-G5, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S3G5
3 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
What motor is it?
Daniel Blakey - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 305
