Giriş
Using a PH00 screwdriver, wire cutters and a soldering station, this guide will show the steps necessary to replace the ball motor.
Neye ihtiyacın var
Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
Remove all seven 9.2mm (0.32 in) screws on the back of the vacuum.
Remove the three 11.5mm (0.45 in) screws at bottom of bead cylinder container using the PH00 screwdriver.
Bir başkası bu kılavuzu tamamladı.
