Ana içeriğe geç
Casdon Dyson Ball Ball Motor Replacement
Neye ihtiyacın var
  1. Casdon Dyson Ball Ball Motor Replacement, Battery: adım 1, 1 resimden 1.
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball Ball Motor Replacement: adım 2, 1 resimden 1.
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Casdon Dyson Ball Ball Motor Replacement, Casdon Dyson Ball Disassembly: adım 3, 1 resimden 1.
    • Remove all seven 9.2mm (0.32 in) screws on the back of the vacuum.
  4. Casdon Dyson Ball Ball Motor Replacement: adım 4, 1 resimden 1.
    • Remove the front side covers by pulling them away from the vacuum.
  5. Casdon Dyson Ball Ball Motor Replacement: adım 5, 1 resimden 1.
    • Separate the battery compartment from the ball and bead cylinder by sliding the vacuum ball away from the battery compartment.
  6. Casdon Dyson Ball Ball Motor Replacement: adım 6, 1 resimden 1.
    • Separate the bead cylinder and the fan compartment by pulling the bead cylinder away from the fan compartment.
  7. Casdon Dyson Ball Ball Motor Replacement: adım 7, 1 resimden 1.
    • Remove beads from the container.
  8. Casdon Dyson Ball Ball Motor Replacement, Ball Motor: adım 8, 1 resimden 1.
    • Remove the three 11.5mm (0.45 in) screws at bottom of bead cylinder container using the PH00 screwdriver.
  9. Casdon Dyson Ball Ball Motor Replacement: adım 9, 1 resimden 1.
    • Remove the bead cylinder and motor mount from the vacuum ball.
  10. Casdon Dyson Ball Ball Motor Replacement: adım 10, 1 resimden 1.
    • Separate the motor mount from the bead cylinder by pulling the motor mount away from the bead cylinder.
  11. Casdon Dyson Ball Ball Motor Replacement: adım 11, 1 resimden 1.
    • Separate the fan from the motor shaft by pulling the fan away from the motor.
  12. Casdon Dyson Ball Ball Motor Replacement: adım 12, 1 resimden 1.
    • Cut the wires to the faulty motor using wire cutters.
  13. Casdon Dyson Ball Ball Motor Replacement: adım 13, 1 resimden 1.
    • Remove and replace the faulty ball motor with a new one.
    • Solder the new ball motor's wires to the vacuum's wires which were previously cut.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Seldon Price
612 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G5, Harley Fall 2017 IUPUI, Team S3-G5, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S3G5
3 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
Thank you for the guide, it helped me successfully repair the top motor that stirs the colored pellets. My son will be so happy to see it working again!
Garrett - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 658
