Ana içeriğe geç
Casdon Dyson Ball Disassembly
Neye ihtiyacın var
  1. Casdon Dyson Ball Disassembly, Battery: adım 1, 1 resimden 1.
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball Disassembly: adım 2, 1 resimden 1.
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Casdon Dyson Ball Disassembly, Casdon Dyson Ball Disassembly: adım 3, 1 resimden 1.
    • Remove all seven 9.2mm (0.32 in) screws on the back of the vacuum.
  4. Casdon Dyson Ball Disassembly: adım 4, 1 resimden 1.
    • Remove the front side covers by pulling them away from the vacuum.
  5. Casdon Dyson Ball Disassembly: adım 5, 1 resimden 1.
    • Separate the battery compartment from the ball and bead cylinder by sliding the vacuum ball away from the battery compartment.
  6. Casdon Dyson Ball Disassembly: adım 6, 1 resimden 1.
    • Separate the bead cylinder and the fan compartment by pulling the bead cylinder away from the fan compartment.
  7. Casdon Dyson Ball Disassembly: adım 7, 1 resimden 1.
    • Remove beads from the container.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Seldon Price
612 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G5, Harley Fall 2017 IUPUI, Team S3-G5, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S3G5
3 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
How do I get the handle out once assembled?
Carie McClendon - Yanıt
The fan to make the beads jump around no longer works….is there. Separate battery for that?
Kathy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 26
Son 30 gün: 109
Her zaman: 12,437
