Ana içeriğe geç
Casdon Dyson Ball On/Off Switch Replacement
Neye ihtiyacın var
  1. Casdon Dyson Ball On/Off Switch Replacement, Battery: adım 1, 1 resimden 1.
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball On/Off Switch Replacement: adım 2, 1 resimden 1.
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Casdon Dyson Ball On/Off Switch Replacement, On/Off Switch: adım 3, 1 resimden 1.
    • Remove four 9.2mm (0.32 in) screws from the back of the vacuum using the PH00 screwdriver.
  4. Casdon Dyson Ball On/Off Switch Replacement: adım 4, 1 resimden 1.
    • Remove the cover to the on/off switch by pulling up on the cover from the front of the vacuum.
  5. Casdon Dyson Ball On/Off Switch Replacement: adım 5, 1 resimden 1.
    • Cut the two wires connected to the on/off switch using a set of wire cutters.
  6. Casdon Dyson Ball On/Off Switch Replacement: adım 6, 1 resimden 1.
    • Remove the two 9.2mm (0.32 in) screws which hold the on/off switch to the vacuum using the PH00 screwdriver.
  7. Casdon Dyson Ball On/Off Switch Replacement: adım 7, 1 resimden 1.
    • Remove the on/off switch by pulling it away from the vacuum with your fingers.
    • Replace the faulty on/off switch with the new on/off switch.
    • Solder the new on/off switch's wires to the vacuum's wires using a soldering station.
Sonuç
Seldon Price
612 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G5, Harley Fall 2017 IUPUI, Team S3-G5, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S3G5
3 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
Great instructions but where can you purchase the on of switch and what is the part number?
debbyh1024 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 17
Her zaman: 2,122
