Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Flip the keyboard over so that the bottom is facing up.
Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
Remove the bottom panel by lifting and pulling it towards yourself.
Flip open the top half of the keyboard.
Set the keyboard onto the bottom half with the internal parts facing up.
Plug in the soldering iron.
Unscrew the top green circuit board with black and red wires running through it.
Set the circuit board somewhere flat so it is safe to solder.
Heat up the solder covering the end of the wires connected to the circuit board.
Once the solder melts, remove the wires from the circuit board.
Melt new solder with your soldering iron.
Then apply it over the tip of the wire resting on the circuit board.
Once the wires are firmly attached, screw the circuit board back into the keyboard.
3 farklı kişi bu kılavuzu tamamladı.
