Ana içeriğe geç
Casio CTK-501 Buttons Replacement
Neye ihtiyacın var
  1. Casio CTK-501 Buttons Replacement, Bottom Panel: adım 1, 2 resimden 1. Casio CTK-501 Buttons Replacement, Bottom Panel: adım 1, 2 resimden 2.
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Buttons Replacement: adım 2, 1 resimden 1.
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Buttons Replacement: adım 3, 2 resimden 1. Casio CTK-501 Buttons Replacement: adım 3, 2 resimden 2.
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Buttons Replacement, Buttons: adım 4, 1 resimden 1.
    • Remove the nine screws from the brown circuit board that has an attached ribbon, with a #0 Phillips.
  5. Casio CTK-501 Buttons Replacement: adım 5, 1 resimden 1.
    • Remove the circuit board, by pulling upwards.
  6. Casio CTK-501 Buttons Replacement: adım 6, 1 resimden 1.
    • Remove the buttons.
  7. Casio CTK-501 Buttons Replacement: adım 7, 1 resimden 1.
    • Place the new buttons into the slot, and push downward in the slot.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jimmy Winne
578 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-16, Amido Fall 2012 Cal Poly, Team 9-16, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S9G16
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 2,278
