Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Flip the keyboard over so that the bottom is facing up.
Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
Remove the bottom panel by lifting and pulling it towards yourself.
Flip open the top half of the keyboard.
Set the keyboard onto the bottom half with the internal parts facing up.
Remove the nine screws from the brown circuit board that has an attached ribbon, with a #0 Phillips.
Place the new buttons into the slot, and push downward in the slot.
2 farklı kişi bu kılavuzu tamamladı.
