Ana içeriğe geç
Casio CTK-501 Keys Replacement
Neye ihtiyacın var
  1. Casio CTK-501 Keys Replacement, Bottom Panel: adım 1, 2 resimden 1. Casio CTK-501 Keys Replacement, Bottom Panel: adım 1, 2 resimden 2.
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Keys Replacement: adım 2, 1 resimden 1.
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Keys Replacement: adım 3, 2 resimden 1. Casio CTK-501 Keys Replacement: adım 3, 2 resimden 2.
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Keys Replacement, Keys: adım 4, 1 resimden 1.
    • Completely unscrew and remove the screws holding the broken string of keys in place.
  5. Casio CTK-501 Keys Replacement: adım 5, 1 resimden 1.
    • Pull up the top layer of white keys to remove them from the keyboard.
  6. Casio CTK-501 Keys Replacement: adım 6, 1 resimden 1.
    • Pull up on the last layer of white keys to remove them.
  7. Casio CTK-501 Keys Replacement: adım 7, 1 resimden 1.
    • Push the black keys toward the front of the keyboard and rotate them until they fall out of the keyboard.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Jimmy Winne
578 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-16, Amido Fall 2012 Cal Poly, Team 9-16, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S9G16
4 Üyeler
4Kılavuz Yorumları
my ctk710 keybord circuit failure.... how to get new circuit in online plg help me
michael Akhil - Yanıt
Please do you know where to get Casio CTK700/720 (or compatible) complete Keys set replacement?
Thanks in advance!
Fred from Brasil
Luis Frederico - Yanıt
pliskers@optonline.net
Will replacing keys cure a rattle/chatter that I hear from my middle C and D keys when they are played?
pliskers - Yanıt
I want to repair my Roland Ex 20 keyboard keys because my middle position two keys are muted.
Jit Ghosh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 34
Her zaman: 25,883
