Ana içeriğe geç
Casio CZ-1000 Barrel Plug Replacement
Neye ihtiyacın var
    1. Casio CZ-1000 Barrel Plug Replacement, Backplate: adım 1, 2 resimden 1. Casio CZ-1000 Barrel Plug Replacement, Backplate: adım 1, 2 resimden 2.
      • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
      FixBot'a Sor
      Yorum Ekle
    2. Casio CZ-1000 Barrel Plug Replacement: adım 2, 3 resimden 1. Casio CZ-1000 Barrel Plug Replacement: adım 2, 3 resimden 2. Casio CZ-1000 Barrel Plug Replacement: adım 2, 3 resimden 3.
      • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
      • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
      FixBot'a Sor
      Yorum Ekle
    3. Casio CZ-1000 Barrel Plug Replacement: adım 3, 3 resimden 1. Casio CZ-1000 Barrel Plug Replacement: adım 3, 3 resimden 2. Casio CZ-1000 Barrel Plug Replacement: adım 3, 3 resimden 3.
      • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
      • Be sure to avoid cutting any nearby wires or components.
      • Gently slide all the plugs out of their sockets.
      • This will prevent them from catching on anything or damaging the connectors as you lift.
      FixBot'a Sor
      Yorum Ekle
    1. Casio CZ-1000 Barrel Plug Replacement, Barrel Plug: adım 4, 1 resimden 1.
      • Clean the area around the barrel plug on the board using a lint-free cloth or a paper towel to remove dust or debris.
      • This ensures a clean working surface and better visibility of the solder joints.
      FixBot'a Sor
      Yorum Ekle
    2. Casio CZ-1000 Barrel Plug Replacement: adım 5, 2 resimden 1. Casio CZ-1000 Barrel Plug Replacement: adım 5, 2 resimden 2.
      • Hold the soldering iron against the solder joint for a few seconds to melt it, then gently pull the barrel plug out while the solder is liquid.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jace Alexander
181 İtibar
2 adet Kılavuz yazıldı
Ekip
Cuesta, Team 60-3, Krynen Fall 2024 Cuesta, Team 60-3, Krynen Fall 2024 üyesi
CUESTA-KRYNEN-F24S60G3
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 29
Her zaman: 315
