Ana içeriğe geç
Casio CZ-1000 Display Screen Replacement
Neye ihtiyacın var
  1. Casio CZ-1000 Display Screen Replacement, Backplate: adım 1, 2 resimden 1. Casio CZ-1000 Display Screen Replacement, Backplate: adım 1, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
    FixBot'a Sor
    Yorum Ekle
  2. Casio CZ-1000 Display Screen Replacement: adım 2, 3 resimden 1. Casio CZ-1000 Display Screen Replacement: adım 2, 3 resimden 2. Casio CZ-1000 Display Screen Replacement: adım 2, 3 resimden 3.
    • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
    • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
    FixBot'a Sor
    Yorum Ekle
  3. Casio CZ-1000 Display Screen Replacement: adım 3, 3 resimden 1. Casio CZ-1000 Display Screen Replacement: adım 3, 3 resimden 2. Casio CZ-1000 Display Screen Replacement: adım 3, 3 resimden 3.
    • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
    • Be sure to avoid cutting any nearby wires or components.
    • Gently slide all the plugs out of their sockets.
    • This will prevent them from catching on anything or damaging the connectors as you lift.
    FixBot'a Sor
    Yorum Ekle
  4. Casio CZ-1000 Display Screen Replacement, Display Screen: adım 4, 2 resimden 1. Casio CZ-1000 Display Screen Replacement, Display Screen: adım 4, 2 resimden 2.
    • Pull out the orange 24 pin connector.
    • Pull on the orange plastic piece and not the wires. Pulling on the wires can potentially damage the device.
    FixBot'a Sor
    Yorum Ekle
  5. Casio CZ-1000 Display Screen Replacement: adım 5, 2 resimden 1. Casio CZ-1000 Display Screen Replacement: adım 5, 2 resimden 2.
    • Remove the four 7.5 mm screws that are holding down the metal sheets using a Phillips #1 screwdriver.
    • Set the sheet to the side for now.
    FixBot'a Sor
    Yorum Ekle
  6. Casio CZ-1000 Display Screen Replacement: adım 6, 3 resimden 1. Casio CZ-1000 Display Screen Replacement: adım 6, 3 resimden 2. Casio CZ-1000 Display Screen Replacement: adım 6, 3 resimden 3.
    • Remove the four 5.5 mm screws from the corners of the display screen using a Phillips #1 screwdriver.
    • Lift the side of the display screen that is closer to you and then pull out the screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Ayman Benbrahim
97 İtibar
1 Kılavuz yazıldı
Ekip
Cuesta, Team 60-3, Krynen Fall 2024 Cuesta, Team 60-3, Krynen Fall 2024 üyesi
CUESTA-KRYNEN-F24S60G3
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 276
