Ana içeriğe geç
Casio CZ-1000 Piano Key Replacement
Neye ihtiyacın var
  1. Casio CZ-1000 Piano Key Replacement, Backplate: adım 1, 2 resimden 1. Casio CZ-1000 Piano Key Replacement, Backplate: adım 1, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
  2. Casio CZ-1000 Piano Key Replacement: adım 2, 3 resimden 1. Casio CZ-1000 Piano Key Replacement: adım 2, 3 resimden 2. Casio CZ-1000 Piano Key Replacement: adım 2, 3 resimden 3.
    • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
    • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
  3. Casio CZ-1000 Piano Key Replacement: adım 3, 3 resimden 1. Casio CZ-1000 Piano Key Replacement: adım 3, 3 resimden 2. Casio CZ-1000 Piano Key Replacement: adım 3, 3 resimden 3.
    • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
    • Be sure to avoid cutting any nearby wires or components.
    • Gently slide all the plugs out of their sockets.
    • This will prevent them from catching on anything or damaging the connectors as you lift.
  4. Casio CZ-1000 Piano Key Replacement, Piano Key: adım 4, 2 resimden 1. Casio CZ-1000 Piano Key Replacement, Piano Key: adım 4, 2 resimden 2.
    • Remove the four 7.5 mm screws using a Phillips #1 screwdriver.
    • Lift the rectangular circuit board away to expose the underside of the key bed.
  5. Casio CZ-1000 Piano Key Replacement: adım 5, 2 resimden 1. Casio CZ-1000 Piano Key Replacement: adım 5, 2 resimden 2.
    • Remove the six 7.5 mm screws using a Phillips #1 screwdriver.
  6. Casio CZ-1000 Piano Key Replacement: adım 6, 2 resimden 1. Casio CZ-1000 Piano Key Replacement: adım 6, 2 resimden 2.
    • Grab the key bed by the side shown.
    • Lift the key bed up and slide it out from the black case.
  7. Casio CZ-1000 Piano Key Replacement: adım 7, 2 resimden 1. Casio CZ-1000 Piano Key Replacement: adım 7, 2 resimden 2.
    • Flip the key bed over so that the keys are facing up.
    • Using a pair of tweezers, detach the spring from both the metal bar and the key itself.
    • Lift the key out of the slot in the metal bar and replace!
Sonuç
CJ Fagundo
159 İtibar
1 Kılavuz yazıldı
Ekip
Cuesta, Team 60-3, Krynen Fall 2024 Cuesta, Team 60-3, Krynen Fall 2024 üyesi
CUESTA-KRYNEN-F24S60G3
4 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Disassembly went fine, but my cz1000 keys don't look the same
Brian Marshall - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 26
Her zaman: 67
