Ana içeriğe geç
Casio CZ-1000 Power Switch Replacement
Neye ihtiyacın var
  1. Casio CZ-1000 Power Switch Replacement, Backplate: adım 1, 2 resimden 1. Casio CZ-1000 Power Switch Replacement, Backplate: adım 1, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
    FixBot'a Sor
    Yorum Ekle
  2. Casio CZ-1000 Power Switch Replacement: adım 2, 3 resimden 1. Casio CZ-1000 Power Switch Replacement: adım 2, 3 resimden 2. Casio CZ-1000 Power Switch Replacement: adım 2, 3 resimden 3.
    • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
    • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
    FixBot'a Sor
    Yorum Ekle
  3. Casio CZ-1000 Power Switch Replacement: adım 3, 3 resimden 1. Casio CZ-1000 Power Switch Replacement: adım 3, 3 resimden 2. Casio CZ-1000 Power Switch Replacement: adım 3, 3 resimden 3.
    • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
    • Be sure to avoid cutting any nearby wires or components.
    • Gently slide all the plugs out of their sockets.
    • This will prevent them from catching on anything or damaging the connectors as you lift.
    FixBot'a Sor
    Yorum Ekle
  4. Casio CZ-1000 Power Switch Replacement, Power Switch: adım 4, 1 resimden 1.
    • Remove the two 5.5 mm screws holding the power switch to the case using a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Casio CZ-1000 Power Switch Replacement: adım 5, 3 resimden 1. Casio CZ-1000 Power Switch Replacement: adım 5, 3 resimden 2. Casio CZ-1000 Power Switch Replacement: adım 5, 3 resimden 3.
    • Heat the soldering iron and use a desoldering braid or pump to remove the solder from the pins of the old switch.
    • Once the solder is removed, gently pull the old switch out of its place.
    • If the replacement switch doesn’t have pre-attached leads, you’ll need to solder wires to it. If it has leads, align them with the matching holes on the PCB where the old switch was connected.
    • Position the new switch in place, ensuring the leads align correctly with the pads on the PCB. Solder the leads securely, using just enough solder to create a strong connection without any excess that might cause shorts.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Luke Farmer
235 İtibar
1 Kılavuz yazıldı
Ekip
Cuesta, Team 60-3, Krynen Fall 2024 Cuesta, Team 60-3, Krynen Fall 2024 üyesi
CUESTA-KRYNEN-F24S60G3
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 33
Her zaman: 301
