Giriş
If you are having issues with the responsiveness or functionality of the key pad on your Casio Cassiopeia E-125, this guide will walk you through the process in 10-15 minutes.
In Step 9, proceed with caution: Potential for device damage. Do not pull apart the wires connecting the outer case.
Neye ihtiyacın var
Use the Phillips #00 screwdriver to remove the two screws near the top of the device.
Use the Phillips #00 screwdriver and remove the five screws from the daughterboard.
