Ana içeriğe geç
Casio Cassiopeia E-125 Touch Screen Replacement
Neye ihtiyacın var
  1. Casio Cassiopeia E-125 Touch Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the device over to the back side.
  2. Casio Cassiopeia E-125 Touch Screen Replacement: adım 2, 1 resimden 1.
    • Slide the small switch on the back to "MAIN".
  3. Casio Cassiopeia E-125 Touch Screen Replacement: adım 3, 1 resimden 1.
    • Slide the battery cover downwards.
    • Pull off the battery cover.
  4. Casio Cassiopeia E-125 Touch Screen Replacement: adım 4, 1 resimden 1.
    • Pull the black tab to remove the battery.
  5. Casio Cassiopeia E-125 Touch Screen Replacement, Touch Screen: adım 5, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the two screws near the top of the device.
  6. Casio Cassiopeia E-125 Touch Screen Replacement: adım 6, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the two screws located inside the battery compartment.
  7. Casio Cassiopeia E-125 Touch Screen Replacement: adım 7, 1 resimden 1.
    • Use a spudger or opening tool to separate the two halves of the case.
  8. Casio Cassiopeia E-125 Touch Screen Replacement: adım 8, 1 resimden 1.
    • Pry the two halves of the case apart with the opening tool.
  9. Casio Cassiopeia E-125 Touch Screen Replacement: adım 9, 1 resimden 1.
    • Potential for device damage. Do not pull apart the wires connecting the outer case.
    • Lay the two halves of the outer case next to the central components as shown.
  10. Casio Cassiopeia E-125 Touch Screen Replacement: adım 10, 1 resimden 1.
    • Use the Philips #00 screwdriver to remove the three screws in the corners of the screen.
  11. Casio Cassiopeia E-125 Touch Screen Replacement: adım 11, 2 resimden 1. Casio Cassiopeia E-125 Touch Screen Replacement: adım 11, 2 resimden 2.
    • Lift the tab on the motherboard and pull out the ribbon cable.
    • After the ribbon cable is detached from the motherboard, the touch screen is completely separated from the device.
Sonuç
Ryan Fernandez
47 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-4, Forte Spring 2012 Cal Poly, Team 5-4, Forte Spring 2012 üyesi
CPSU-FORTE-S12S5G4
6 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 989
