Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Slide the battery cover downwards.
Pull off the battery cover.
Use the Phillips #00 screwdriver to remove the two screws near the top of the device.
Use the Phillips #00 screwdriver to remove the two screws located inside the battery compartment.
Use a spudger or opening tool to separate the two halves of the case.
Pry the two halves of the case apart with the opening tool.
Lay the two halves of the outer case next to the central components as shown.
Use the Philips #00 screwdriver to remove the three screws in the corners of the screen.
Lift the tab on the motherboard and pull out the ribbon cable.
After the ribbon cable is detached from the motherboard, the touch screen is completely separated from the device.
