Ana içeriğe geç
Casio DW-6900 Watchband Replacement
Neye ihtiyacın var
  1. Casio DW-6900 Watchband  Replacement, Watchband: adım 1, 3 resimden 1. Casio DW-6900 Watchband  Replacement, Watchband: adım 1, 3 resimden 2. Casio DW-6900 Watchband  Replacement, Watchband: adım 1, 3 resimden 3.
    • There are four screws— two on each side of the watch case.
    • Use the Philllips screwdriver to remove four 4.5 mm screws.
  2. Casio DW-6900 Watchband  Replacement: adım 2, 2 resimden 1. Casio DW-6900 Watchband  Replacement: adım 2, 2 resimden 2.
    • There are two trunnions on both sides of the watch, and there are four grooves.
    • Use a small flat-blade screwdriver and push inward to remove the trunnion. And remove the strap.
  3. Casio DW-6900 Watchband  Replacement: adım 3, 1 resimden 1.
    • From the bottom of the watch, buckle the case from the main body of the watch by hand.
  4. Casio DW-6900 Watchband  Replacement: adım 4, 1 resimden 1.
    • Align the hole on the side of the case with the button on the watch and put on the new watch case.
  5. Casio DW-6900 Watchband  Replacement: adım 5, 3 resimden 1. Casio DW-6900 Watchband  Replacement: adım 5, 3 resimden 2. Casio DW-6900 Watchband  Replacement: adım 5, 3 resimden 3.
    • Thread the trunnion into the small hole on the strap.
    • First, snap one side of the trunnion into the hole of the watch body.
    • Use a flat-blade screwdriver to push the other end of the trunnion into the main body of the watch.
  6. Casio DW-6900 Watchband  Replacement: adım 6, 2 resimden 1. Casio DW-6900 Watchband  Replacement: adım 6, 2 resimden 2.
    • Screw on the four screws on both sides of the watch.
Sonuç
Shaoguang He
133 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 70
Her zaman: 2,664
