Ana içeriğe geç
Casio Exilim EX Z55 LCD Screen Replacement
Neye ihtiyacın var
  1. Casio Exilim EX Z55 LCD Screen Replacement, Front Case: adım 1, 3 resimden 1. Casio Exilim EX Z55 LCD Screen Replacement, Front Case: adım 1, 3 resimden 2. Casio Exilim EX Z55 LCD Screen Replacement, Front Case: adım 1, 3 resimden 3.
    • Remove eight 1.8 mm screws from the left and right sides of the camera using a Phillips #00 screwdriver
  2. Casio Exilim EX Z55 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Remove the four 3.7 mm screws from the bottom of the camera using a Phillips #00 screwdriver.
  3. Casio Exilim EX Z55 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Separate the front case from the body of the camera.
  4. Casio Exilim EX Z55 LCD Screen Replacement, Back Case: adım 4, 1 resimden 1.
    • Separate the back case from the body of the camera.
  5. Casio Exilim EX Z55 LCD Screen Replacement, LCD Screen: adım 5, 3 resimden 1. Casio Exilim EX Z55 LCD Screen Replacement, LCD Screen: adım 5, 3 resimden 2. Casio Exilim EX Z55 LCD Screen Replacement, LCD Screen: adım 5, 3 resimden 3.
    • Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up.
  6. Casio Exilim EX Z55 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Before removing the side metal bracket, first remove the attached strap knob by twisting it off.
    • Then, remove the side metal bracket by inserting the plastic opening tool under the bracket and pulling up.
  7. Casio Exilim EX Z55 LCD Screen Replacement: adım 7, 1 resimden 1.
    • Using the plastic opening tool, pry up the LCD screen starting at one of the corners. Insert the tool under one of the corners and lift up.
  8. Casio Exilim EX Z55 LCD Screen Replacement: adım 8, 2 resimden 1. Casio Exilim EX Z55 LCD Screen Replacement: adım 8, 2 resimden 2.
    • Continue to lift the LCD screen all the way up.
    • Be careful not to rip any wires connecting the LCD screen to the top of the camera.
Sonuç
Laura
46 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-45, Regan Spring 2012 Cal Poly, Team 9-45, Regan Spring 2012 üyesi
CPSU-REGAN-S12S9G45
7 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 28
Her zaman: 2,185
