Giriş
Sometimes the gears in lens of the Casio Exilim EX-Z70 get clogged with sand, dirt, or debris and no longer function. Without these gears the lens can not retract or extend from the camera and will appear stuck. This guide will help you access the lens gears for cleaning.
Neye ihtiyacın var
Remove the strap from the camera by pulling the thin cord out, creating a small loop, then pushing the thicker cord back through this loop.
Use a pair of tweezers to gently move the wire around part of the lens away from it so that you can access the lens.
Using tweezers or your finger nails, pull up the brown flaps where the two orange film strips connected to the lens meet the circuit board.
Use the tweezers to pull the orange film strips out of the port. It should come out easily.
There are two additional film strips connected to the circuit board that do not need to be removed. These are connected to the side of the circuit board that is opposite to the lens
Now that the lens is fully exposed, remove the two phillips screws (4.34 mm) on front of the lens.
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Hi dear awesome Guide writter,
I have used the guide on a similar model, the Casio Exilim Z77 (if i am not wrong), in a context where sand and dust were disturbing the mouvments of the lens.
Most of the steps have been simulars. I additionally open the lens were most of the sand had entered.
After my first try yesterday evening, the canera refused to switch on again...
I will re-open this evening to see if any module appear disconneced from the other.
Do you have suggestion how to proceed ?
I have only simple iFixit tools, but no voltage or current measurment (yet).
Best regards,
Michel.
