Giriş
If your lens have cracked, stopped working, or malfunctioned in any other way, you may need to replace the lens. This guide will isolate the lens so that it can be replaced or investigated.
Aletler
Parçalar
Hiçbir parçaya gerek yok.
Remove the strap from the camera by pulling the thin cord out, creating a small loop, then pushing the thicker cord back through this loop.
Use a pair of tweezers to gently move the wire around part of the lens away from it so that you can access the lens.
Using tweezers or your finger nails, pull up the brown flaps where the two orange film strips connected to the lens meet the circuit board.
Use the tweezers to pull the orange film strips out of the port. It should come out easily.
There are two additional film strips connected to the circuit board that do not need to be removed. These are connected to the side of the circuit board that is opposite to the lens
2 başka kişi bu kılavuzu tamamladı.
