Ana içeriğe geç
Casio Exilim EX-Z80 LCD Screen Replacement
Neye ihtiyacın var
  1. Casio Exilim EX-Z80 LCD Screen Replacement, Back and Front Cover: adım 1, 3 resimden 1. Casio Exilim EX-Z80 LCD Screen Replacement, Back and Front Cover: adım 1, 3 resimden 2. Casio Exilim EX-Z80 LCD Screen Replacement, Back and Front Cover: adım 1, 3 resimden 3.
    • Remove the four 3 mm black screws from the bottom of the camera using a Phillips #000 screwdriver.
    • Open the battery compartment with your thumb or index finger.
    • Remove the single 2 mm silver screw that is now exposed using a Phillips #000 screwdriver.
  2. Casio Exilim EX-Z80 LCD Screen Replacement: adım 2, 3 resimden 1. Casio Exilim EX-Z80 LCD Screen Replacement: adım 2, 3 resimden 2. Casio Exilim EX-Z80 LCD Screen Replacement: adım 2, 3 resimden 3.
    • Open the USB port tab.
    • Remove the single 2 mm silver screw using a Phillips #000 screwdriver.
  3. Casio Exilim EX-Z80 LCD Screen Replacement: adım 3, 2 resimden 1. Casio Exilim EX-Z80 LCD Screen Replacement: adım 3, 2 resimden 2.
    • Remove the two 2 mm silver screws using a Phillips #000 screwdriver.
  4. Casio Exilim EX-Z80 LCD Screen Replacement: adım 4, 2 resimden 1. Casio Exilim EX-Z80 LCD Screen Replacement: adım 4, 2 resimden 2.
    • Carefully remove the silver strip from left side. Open the battery cover and remove the metal strip with fingers by sliding it to the left.
  5. Casio Exilim EX-Z80 LCD Screen Replacement: adım 5, 2 resimden 1. Casio Exilim EX-Z80 LCD Screen Replacement: adım 5, 2 resimden 2.
    • With the metal spudger, pry out the edge of the silver strip at the bottom right side of the camera.
    • Carefully remove the remaining part of the metal strip.
  6. Casio Exilim EX-Z80 LCD Screen Replacement: adım 6, 2 resimden 1. Casio Exilim EX-Z80 LCD Screen Replacement: adım 6, 2 resimden 2.
    • Remove the two 2 mm silver screws from the top corners of the camera using a Phillips #000 screwdriver.
    • Remove the three 2 mm screws from the left side using a Phillips #000 screwdriver.
  7. Casio Exilim EX-Z80 LCD Screen Replacement: adım 7, 3 resimden 1. Casio Exilim EX-Z80 LCD Screen Replacement: adım 7, 3 resimden 2. Casio Exilim EX-Z80 LCD Screen Replacement: adım 7, 3 resimden 3.
    • Using a small opening tool carefully release all lock tabs at the top and on the side of the camera from their locked position.
    • Using your hands, carefully separate the front and back panel from the camera.
  8. Casio Exilim EX-Z80 LCD Screen Replacement, LCD Screen: adım 8, 3 resimden 1. Casio Exilim EX-Z80 LCD Screen Replacement, LCD Screen: adım 8, 3 resimden 2. Casio Exilim EX-Z80 LCD Screen Replacement, LCD Screen: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Gently flip the wide button cable up from the display cable.
    • Lift the brown retention flap on the display cable ZIF connector with tweezers or an ESD-safe tool.
    • Carefully pull the display cable from its connector.
  9. Casio Exilim EX-Z80 LCD Screen Replacement: adım 9, 3 resimden 1. Casio Exilim EX-Z80 LCD Screen Replacement: adım 9, 3 resimden 2. Casio Exilim EX-Z80 LCD Screen Replacement: adım 9, 3 resimden 3.
    • Pry the square holes that hold the LCD screen up with a metal spudger until you see the raised tabs in the metal holes.
    • Repeat the process with the holes around the four edges of the camera.
    • Insert the metal spudger into the gap of the metal case and pry up the LCD screen.
  10. Casio Exilim EX-Z80 LCD Screen Replacement: adım 10, 3 resimden 1. Casio Exilim EX-Z80 LCD Screen Replacement: adım 10, 3 resimden 2. Casio Exilim EX-Z80 LCD Screen Replacement: adım 10, 3 resimden 3.
    • Hold up the LCD screen in one hand and hold back the button cable with the other.
    • Don't let the LCD screen to fall back into the metal case and make sure the button cable does not get stuck on the display cable.
    • Pull on the LCD screen until the yellow display cable is fully out of the metal case.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 646
