Ana içeriğe geç
Casio Exilim EX-Z850 Battery Casing Disassembly
Neye ihtiyacın var
    1. Casio Exilim EX-Z850 Battery Casing Disassembly, Casio Exilim EX-Z850 Battery Casing Disassembly: adım 1, 1 resimden 1.
      • Remove battery before you begin disassembly.
      • Use a Phillips #00 Screwdriver to remove all four of the screws on the right side of the camera with the lens facing you.
      FixBot'a Sor
      Yorum Ekle
    2. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 2, 1 resimden 1.
      • Use a Phillips #00 screwdriver, unscrew all four screws on the left side of the camera.
      FixBot'a Sor
      Yorum Ekle
    3. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 3, 1 resimden 1.
      • Use the Phillips #00 screwdriver to remove all four of the screws on the bottom of the camera.
      • Bottom screws are longer than the top screws, so label accordingly for easy reassembly.
      FixBot'a Sor
      Yorum Ekle
    4. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 4, 3 resimden 1. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 4, 3 resimden 2. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 4, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Once all screws have been removed, slowly pry open the back casing of the camera.
      • Gently remove the ribbon cable from the LCD with tweezers.
      • Set aside back casing of the camera.
      FixBot'a Sor
      Yorum Ekle
    5. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 5, 2 resimden 1. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 5, 2 resimden 2.
      • Use your tweezers to hold the camera secure, while you pull the front cover off of the camera.
      FixBot'a Sor
      Yorum Ekle
    6. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 6, 2 resimden 1. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 6, 2 resimden 2.
      • The bottom of the LCD screen is secured to the frame by small pieces of black tape. You will need to peel the tape away to release the LCD screen.
      • Use your tweezers to lift the LCD screen from the frame.
      FixBot'a Sor
      Yorum Ekle
    7. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 7, 2 resimden 1. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 7, 2 resimden 2.
      • Lift screen away from the camera with your tweezers.
      • Flip screen over gently with your fingers once it is lifted far away enough from the camera.
      FixBot'a Sor
      Yorum Ekle
    8. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 8, 1 resimden 1.
      • Use your tweezers to lift the LCD frame from the camera.
      FixBot'a Sor
      Yorum Ekle
    9. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 9, 3 resimden 1. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 9, 3 resimden 2. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 9, 3 resimden 3.
      • Use your tweezers to lift the bar holding the ribbon off.
      • Disconnect the ribbon to release the LCD screen.
      • Use your fingers to pull the LCD screen with the attached ribbon from the camera.
      FixBot'a Sor
      Yorum Ekle
    10. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 10, 2 resimden 1. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 10, 2 resimden 2.
      • Use a Phillips #00 screwdriver to remove the two screws from the side of the camera that has the strap mount.
      • Remove strap mount by slowly pulling the side of the case so it will dislocate from the top of the camera.
      FixBot'a Sor
      Yorum Ekle
    11. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 11, 2 resimden 1. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 11, 2 resimden 2.
      • Hold the camera facing toward you. Pull up the bar that is securing the ribbon located to the left of the flash.
      • Disconnect the ribbon by prying it off with your fingers.
      FixBot'a Sor
      Yorum Ekle
    12. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 12, 3 resimden 1. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 12, 3 resimden 2. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 12, 3 resimden 3.
      • With the lens facing towards you, pull the L-shaped frame away from the camera.
      • Do not disconnect any of the wires from the camera when pulling the frame.
      • Remove the frame from the two studs and metal tabs keeping it in place at the bottom of the camera.
      FixBot'a Sor
      Yorum Ekle
    13. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 13, 2 resimden 1. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 13, 2 resimden 2.
      • Locate the logic board to the left of the lens. You will see a bar securing a ribbon. Flip the bar up to release the ribbon.
      • Disconnect the ribbon.
      FixBot'a Sor
      Yorum Ekle
    14. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 14, 2 resimden 1. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 14, 2 resimden 2.
      • Use your Phillips #00 screwdriver to remove the two screws connecting the frame to the back of the camera.
      • Lift the frame away on the LCD screen side of the camera.
      FixBot'a Sor
      Yorum Ekle
    15. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 15, 2 resimden 1. Casio Exilim EX-Z850 Battery Casing Disassembly: adım 15, 2 resimden 2.
      • This is what your camera should look like now that you have the battery casing isolated.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Logan
313 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-38, Regan Winter 2011 Cal Poly, Team 4-38, Regan Winter 2011 üyesi
CPSU-REGAN-W11S4G38
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 50
Her zaman: 4,495
