Ana içeriğe geç
Casio Exilim EX-Z850 Outer Case Replacement
Neye ihtiyacın var
  1. Casio Exilim EX-Z850 Outer Case Replacement, Outer Case: adım 1, 3 resimden 1. Casio Exilim EX-Z850 Outer Case Replacement, Outer Case: adım 1, 3 resimden 2. Casio Exilim EX-Z850 Outer Case Replacement, Outer Case: adım 1, 3 resimden 3.
    • Remove all four screws on the camera's side using a Phillips #00 screwdriver.
    • Remove all four screws on the opposite side of the camera using the same screwdriver.
    • Remove all four screws on the bottom of the camera using the same screwdriver.
    • The bottom screws are longer than the top screws, so label them accordingly for easy reassembly.
  2. Casio Exilim EX-Z850 Outer Case Replacement: adım 2, 3 resimden 1. Casio Exilim EX-Z850 Outer Case Replacement: adım 2, 3 resimden 2. Casio Exilim EX-Z850 Outer Case Replacement: adım 2, 3 resimden 3.
    • Pry open the bottom casing.
    • Remove the ribbon from the LCD screen using the tweezers and set aside the bottom casing.
    • These steps should be taken carefully in order to prevent damage to the camera.
  3. Casio Exilim EX-Z850 Outer Case Replacement: adım 3, 2 resimden 1. Casio Exilim EX-Z850 Outer Case Replacement: adım 3, 2 resimden 2.
    • Pry apart the top casing using tweezers.
    • Remove the top casing from the camera and set aside the top casing.
Sonuç
To reassemble your device, follow these instructions in reverse order, starting with reattaching the top casing.
2 farklı kişi bu kılavuzu tamamladı.
Logan
313 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-38, Regan Winter 2011 Cal Poly, Team 4-38, Regan Winter 2011 üyesi
CPSU-REGAN-W11S4G38
4 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 9
Her zaman: 3,041
