Ana içeriğe geç
Casio FX-115MS Keyboard Mat Replacement
Neye ihtiyacın var
  1. Casio FX-115MS  Keyboard Mat Replacement, Back Plate: adım 1, 1 resimden 1.
    • Remove the 6 screws, which are 5mm long, using a PH1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Casio FX-115MS  Keyboard Mat Replacement: adım 2, 3 resimden 1. Casio FX-115MS  Keyboard Mat Replacement: adım 2, 3 resimden 2. Casio FX-115MS  Keyboard Mat Replacement: adım 2, 3 resimden 3.
    • Use plastic spudger to separate backplate from the front-plate. Place the flat end of the spudger in the seam between the front and back, near one end of the calculator. Then slide the spudger towards the calculator's center. The two sides will pop free from each other as you go through it with the spudger.
    FixBot'a Sor
    Yorum Ekle
  3. Casio FX-115MS  Keyboard Mat Replacement, Battery: adım 3, 2 resimden 1. Casio FX-115MS  Keyboard Mat Replacement, Battery: adım 3, 2 resimden 2.
    • Using the pointed end of the nylon spudger, carefully pry an edge of the battery, and lift the battery from its socket.
    FixBot'a Sor
    Yorum Ekle
  4. Casio FX-115MS  Keyboard Mat Replacement, Motherboard and Screen: adım 4, 2 resimden 1. Casio FX-115MS  Keyboard Mat Replacement, Motherboard and Screen: adım 4, 2 resimden 2.
    • Using the plastic spudger, carefully pry the battery terminals from the front plate. If the plastic spudger is too weak for prying out the terminals, use the small metal spudger.By Carefully bending and/or prying the little teeth on the terminals upwards you can easily remove them.
    FixBot'a Sor
    Yorum Ekle
  5. Casio FX-115MS  Keyboard Mat Replacement: adım 5, 3 resimden 1. Casio FX-115MS  Keyboard Mat Replacement: adım 5, 3 resimden 2. Casio FX-115MS  Keyboard Mat Replacement: adım 5, 3 resimden 3.
    • Using the small metal spudger. Carefully pry around the edge of the solar panel until it becomes loose. Then simply pull it from its socket using your hands.
    FixBot'a Sor
    Yorum Ekle
  6. Casio FX-115MS  Keyboard Mat Replacement: adım 6, 2 resimden 1. Casio FX-115MS  Keyboard Mat Replacement: adım 6, 2 resimden 2.
    • Using a PH0 phillips screwdriver, unscrew the four, 4mm, pan head screws from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. Casio FX-115MS  Keyboard Mat Replacement: adım 7, 3 resimden 1. Casio FX-115MS  Keyboard Mat Replacement: adım 7, 3 resimden 2. Casio FX-115MS  Keyboard Mat Replacement: adım 7, 3 resimden 3.
    • Carefully lift the motherboard, screen, solar panel, and battery terminal combination from the front plate. Start from the motherboard and lift at an angle toward the solar panel.
    FixBot'a Sor
    Yorum Ekle
  8. Casio FX-115MS  Keyboard Mat Replacement, Keyboard Mat: adım 8, 3 resimden 1. Casio FX-115MS  Keyboard Mat Replacement, Keyboard Mat: adım 8, 3 resimden 2. Casio FX-115MS  Keyboard Mat Replacement, Keyboard Mat: adım 8, 3 resimden 3.
    • Starting from one corner of the keyboard mat, slowly peel the mat from the front plate and individual keys.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Fady Baskharoun
274 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Nance Fall 2016 USF Tampa, Team 2-2, Nance Fall 2016 üyesi
USFT-NANCE-F16S2G2
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 54
Her zaman: 892
