Ana içeriğe geç
Casio FX-115MS Battery Replacement
Neye ihtiyacın var
  1. Casio FX-115MS Battery Replacement, Back Plate: adım 1, 1 resimden 1.
    • Remove the 6 screws, which are 5mm long, using a PH1 screwdriver.
  2. Casio FX-115MS Battery Replacement: adım 2, 3 resimden 1. Casio FX-115MS Battery Replacement: adım 2, 3 resimden 2. Casio FX-115MS Battery Replacement: adım 2, 3 resimden 3.
    • Use plastic spudger to separate backplate from the front-plate. Place the flat end of the spudger in the seam between the front and back, near one end of the calculator. Then slide the spudger towards the calculator's center. The two sides will pop free from each other as you go through it with the spudger.
  3. Casio FX-115MS Battery Replacement, Battery: adım 3, 2 resimden 1. Casio FX-115MS Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Using the pointed end of the nylon spudger, carefully pry an edge of the battery, and lift the battery from its socket.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Lindsey Griffin
454 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Nance Fall 2016 USF Tampa, Team 2-2, Nance Fall 2016 üyesi
USFT-NANCE-F16S2G2
4 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 18
Son 30 gün: 102
Her zaman: 6,494
