Ana içeriğe geç
Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement
Neye ihtiyacın var
    1. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Battery: adım 1, 1 resimden 1.
      • Slide the slider on the back of the phone to the free position.
      FixBot'a Sor
      Yorum Ekle
    2. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: adım 2, 1 resimden 1.
      • Using a plastic opening tool, gently lift open the back panel from bottom of the panel.
      FixBot'a Sor
      Yorum Ekle
    3. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: adım 3, 2 resimden 1. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: adım 3, 2 resimden 2.
      • Pull the white battery tab upwards and remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Motherboard: adım 4, 1 resimden 1.
      • Remove the four 6mm Y0 screws from the corners of the device.
      FixBot'a Sor
      Yorum Ekle
    2. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: adım 5, 1 resimden 1.
      • Remove the four 5mm Y0 screws from the back of the device.
      FixBot'a Sor
      Yorum Ekle
    3. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: adım 6, 1 resimden 1.
      • Using a spudger, pry away the motherboard from its compartment, by inserting the spudger in the compartment and lifting upwards until fully out.
      FixBot'a Sor
      Yorum Ekle
    4. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: adım 7, 1 resimden 1.
      • Lastly, using your hands, separate the motherboard from its compartment.
      FixBot'a Sor
      Yorum Ekle
    1. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: adım 8, 3 resimden 1. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: adım 8, 3 resimden 2. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: adım 8, 3 resimden 3.
      • Using a spudger, gently lift up the orange connector.
      FixBot'a Sor
      Yorum Ekle
    2. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: adım 9, 2 resimden 1. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: adım 9, 2 resimden 2.
      • Flip over the motherboard
      • Using a spudger, lift up the small black connector and remove the camera.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Zack Almeida
392 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G7, Peak Fall 2018 UMass Dartmouth, Team S3-G7, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S3G7
3 Üyeler
38 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 29
Her zaman: 423
