Ana içeriğe geç
Casio G’zOne Commando 4G LTE Battery Replacement
Neye ihtiyacın var
  1. Casio G’zOne Commando 4G LTE Battery Replacement, Battery: adım 1, 1 resimden 1.
    • In order to get at the battery, you will have to pull the locking tab to the “Free” position. Once you do that you will have to pry the battery cover off (using a plastic opening tool or similar prying tool). Because the phone is designed to be waterproof, it is advised that you do NOT use your fingernails.
  2. Casio G’zOne Commando 4G LTE Battery Replacement: adım 2, 2 resimden 1. Casio G’zOne Commando 4G LTE Battery Replacement: adım 2, 2 resimden 2.
    • Once the battery cover is off, there is another lock holding the battery in place. However, with this lock all you have to do is slide the lock to “Free”, and pull the battery out by lifting it from the bottom side (the side with the orange lock).
Sonuç
To install a new battery in your device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Daniel Keenan
374 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-9, Miles Fall 2015 UMass Dartmouth, Team 1-9, Miles Fall 2015 üyesi
UMASSD-MILES-F15S1G9
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 737
