Ana içeriğe geç
Casio G’zOne Commando 4G LTE Motherboard Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Casio G’zOne Commando 4G LTE Motherboard Replacement, Open back cover.: adım 1, 1 resimden 1.
    • This device is waterproof and well sealed, so it is difficult to open this handset.
    • Start by opening the cover of the handset.
    • Do not use your nails to open the cover. Use the iFixit Opening Tool (refer to the image).
  2. Casio G’zOne Commando 4G LTE Motherboard Replacement, Free and remove the battery: adım 2, 2 resimden 1. Casio G’zOne Commando 4G LTE Motherboard Replacement, Free and remove the battery: adım 2, 2 resimden 2.
    • Move the orange tab to the right side to take out the battery.
    • Remove the battery.
  3. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove front and back screws: adım 3, 2 resimden 1. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove front and back screws: adım 3, 2 resimden 2.
    • Using the Phillips #00 screwdriver remove the front and back 5.0 mm screws as shown in the picture.
    • There are four screws in the back and two screws in the front.
  4. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove side-Back cover: adım 4, 3 resimden 1. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove side-Back cover: adım 4, 3 resimden 2. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove side-Back cover: adım 4, 3 resimden 3.
    • Gently remove the side cover from the phone by lifting up on the corners as shown in the picture.
    • Press down on the screen to help remove the plastic side cover from the phone.
    • Make sure to push gently because the frame is fragile.
  5. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove Side-Front cover: adım 5, 1 resimden 1.
    • Pull the side front cover off the face of the phone.
  6. Casio G’zOne Commando 4G LTE Motherboard Replacement: adım 6, 3 resimden 1. Casio G’zOne Commando 4G LTE Motherboard Replacement: adım 6, 3 resimden 2. Casio G’zOne Commando 4G LTE Motherboard Replacement: adım 6, 3 resimden 3.
    • Remove the eight 2.5mm Phillips #00 screws in the holes of the casing.
  7. Casio G’zOne Commando 4G LTE Motherboard Replacement: adım 7, 1 resimden 1.
    • Gently pull off the motherboard cover.
  8. Casio G’zOne Commando 4G LTE Motherboard Replacement: adım 8, 1 resimden 1.
    • Using the Phillips #00, remove all 2.5 mm screws attached to the motherboard.
    • Do not touch the integrated circuits in the motherboard.
  9. Casio G’zOne Commando 4G LTE Motherboard Replacement, Motherboard: adım 9, 2 resimden 1. Casio G’zOne Commando 4G LTE Motherboard Replacement, Motherboard: adım 9, 2 resimden 2.
    • Gently remove the motherboard with the spudger.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Brett Boehm
281 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Brown Fall 2014 USF Tampa, Team 1-5, Brown Fall 2014 üyesi
USFT-BROWN-F14S1G5
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 881
