Ana içeriğe geç
Casio G’zOne Commando 4G LTE Volume Buttons Replacement
Neye ihtiyacın var
  1. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove front and back screws: adım 1, 2 resimden 1. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove front and back screws: adım 1, 2 resimden 2.
    • Using the Phillips #00 screwdriver remove the front and back 5.0 mm screws as shown in the picture.
    • There are four screws in the back and two screws in the front.
  2. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove side-Back cover: adım 2, 3 resimden 1. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove side-Back cover: adım 2, 3 resimden 2. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove side-Back cover: adım 2, 3 resimden 3.
    • Gently remove the side cover from the phone by lifting up on the corners as shown in the picture.
    • Press down on the screen to help remove the plastic side cover from the phone.
    • Make sure to push gently because the frame is fragile.
  3. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove Side-Front cover: adım 3, 1 resimden 1.
    • Pull the side front cover off the face of the phone.
  4. Casio G’zOne Commando 4G LTE Volume Buttons Replacement: adım 4, 3 resimden 1. Casio G’zOne Commando 4G LTE Volume Buttons Replacement: adım 4, 3 resimden 2. Casio G’zOne Commando 4G LTE Volume Buttons Replacement: adım 4, 3 resimden 3.
    • Remove the eight 2.5mm Phillips #00 screws in the holes of the casing.
  5. Casio G’zOne Commando 4G LTE Volume Buttons Replacement: adım 5, 1 resimden 1.
    • Gently pull off the motherboard cover.
  6. Casio G’zOne Commando 4G LTE Volume Buttons Replacement: adım 6, 1 resimden 1.
    • Using the Phillips #00, remove all 2.5 mm screws attached to the motherboard.
    • Do not touch the integrated circuits in the motherboard.
  7. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Motherboard: adım 7, 2 resimden 1. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Motherboard: adım 7, 2 resimden 2.
    • Gently remove the motherboard with the spudger.
  8. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Removing external volume pads: adım 8, 2 resimden 1. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Removing external volume pads: adım 8, 2 resimden 2.
    • Following step 4 in the prerequisite guide, remove the volume pads located on the side of the phone with a gentle pull.
  9. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Removing internal volume buttons: adım 9, 1 resimden 1.
    • Following step 6, remove the adapter connecting the volume buttons to the motherboard.
Sonuç
Brett Boehm
281 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Brown Fall 2014 USF Tampa, Team 1-5, Brown Fall 2014 üyesi
USFT-BROWN-F14S1G5
3 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 11
Her zaman: 170
