Ana içeriğe geç
Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement
Neye ihtiyacın var
  1. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the slider on the back of the phone to the free position.
  2. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: adım 2, 1 resimden 1.
    • Using a plastic opening tool, gently lift open the back panel from bottom of the panel.
  3. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: adım 3, 2 resimden 1. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: adım 3, 2 resimden 2.
    • Pull the white battery tab upwards and remove the battery.
  4. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement, Motherboard: adım 4, 1 resimden 1.
    • Remove the four 6mm Y0 screws from the corners of the device.
  5. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the four 5mm Y0 screws from the back of the device.
  6. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: adım 6, 1 resimden 1.
    • Using a spudger, pry away the motherboard from its compartment, by inserting the spudger in the compartment and lifting upwards until fully out.
  7. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: adım 7, 1 resimden 1.
    • Lastly, using your hands, separate the motherboard from its compartment.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Zack Almeida
392 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G7, Peak Fall 2018 UMass Dartmouth, Team S3-G7, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S3G7
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 196
