Ana içeriğe geç
Casio G'zOne Commando Verizon MIL-SPEC Sim Card Replacement
Neye ihtiyacın var
  1. Casio G'zOne Commando Verizon MIL-SPEC Sim Card Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the slider on the back of the phone to the free position.
  2. Casio G'zOne Commando Verizon MIL-SPEC Sim Card Replacement: adım 2, 1 resimden 1.
    • Using a plastic opening tool, gently lift open the back panel from bottom of the panel.
  3. Casio G'zOne Commando Verizon MIL-SPEC Sim Card Replacement: adım 3, 2 resimden 1. Casio G'zOne Commando Verizon MIL-SPEC Sim Card Replacement: adım 3, 2 resimden 2.
    • Pull the white battery tab upwards and remove the battery.
  4. Casio G'zOne Commando Verizon MIL-SPEC Sim Card Replacement, Sim Card: adım 4, 1 resimden 1.
    • Using a spudger, gently open the metal tab up. Now, it is ready for you to insert the new SIM card.
    That’s not a SIM card slot, that’s an SD card slot. You can’t install a SIM on the Casio G’Zone
    Alan Karna - Yanıt
Sonuç
Zack Almeida
392 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G7, Peak Fall 2018 UMass Dartmouth, Team S3-G7, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S3G7
3 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
i believe that is the memory card, not the sim card!
Joshua Vaillancourt - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 23
Her zaman: 2,561
