Giriş
With the help of a screwdriver, you will be able to replace the silicon buttons, so you can hear some tunes again.
Neye ihtiyacın var
Using a JIS-1 screwdriver, remove the seven 11 mm screws located on the back of the keyboard.
First, you will use a PH-1 bit to remove the 17 8mm screws circled in red.
Next, using the same PH-1 bit, you will remove the three 8mm screws hidden under the white wires, circled in orange.
Then, using a JIS-1 bit, we will remove three 7mm screws from the circuit board, circled in yellow.
After removing the circuit board, the last three screws are revealed, circled in green. You will use the PH-1 bit to remove these last screws.
