Ana içeriğe geç
Casio LK-170 Button Replacement
Neye ihtiyacın var
  1. Casio LK-170 Button Replacement, Button: adım 1, 2 resimden 1. Casio LK-170 Button Replacement, Button: adım 1, 2 resimden 2.
    • Using a JIS-1 screwdriver, remove the seven 11 mm screws located on the back of the keyboard.
  2. Casio LK-170 Button Replacement: adım 2, 1 resimden 1.
    • Once all the screws are out, flip the keyboard over and gently pull the middle panel out.
    • Flip the middle panel up so that the component board can be seen.
  3. Casio LK-170 Button Replacement: adım 3, 3 resimden 1. Casio LK-170 Button Replacement: adım 3, 3 resimden 2. Casio LK-170 Button Replacement: adım 3, 3 resimden 3.
    • In this step, you will be removing a total of 26 screws.
    • First, you will use a PH-1 bit to remove the 17 8mm screws circled in red.
    • Next, using the same PH-1 bit, you will remove the three 8mm screws hidden under the white wires, circled in orange.
    • Then, using a JIS-1 bit, we will remove three 7mm screws from the circuit board, circled in yellow.
    • After removing the circuit board, the last three screws are revealed, circled in green. You will use the PH-1 bit to remove these last screws.
  4. Casio LK-170 Button Replacement: adım 4, 1 resimden 1.
    • Once all the screws have been removed, lift the panel and place it face down on the keys.
    • The panel is connected to the keyboard, so do not try to remove it.
  5. Casio LK-170 Button Replacement: adım 5, 2 resimden 1. Casio LK-170 Button Replacement: adım 5, 2 resimden 2.
    • Under the panel are the buttons. Remove them by pulling from any corner with your fingers.
    • Remove all the buttons that need to be replaced.
Sonuç
Eileen Tran
108 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 13-2, Banghart Winter 2017 Cal Poly, Team 13-2, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S13G2
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 678
