Ana içeriğe geç
Casio LK-170 Display Replacement
Neye ihtiyacın var
  1. Casio LK-170 Display Replacement, Display: adım 1, 1 resimden 1.
    • Using JIS-1 screwdriver, remove the seven 11mm screws located on the back of the keyboard.
  2. Casio LK-170 Display Replacement: adım 2, 1 resimden 1.
    • Once all the screws are out, flip the keyboard over and gently pull the middle panel out.
    • Flip this panel up so that the component board can be seen.
  3. Casio LK-170 Display Replacement: adım 3, 3 resimden 1. Casio LK-170 Display Replacement: adım 3, 3 resimden 2. Casio LK-170 Display Replacement: adım 3, 3 resimden 3.
    • We will be removing a total of 26 screws on the component board..
    • First, you must use the PH-1 bit to remove the 17 8mm screws, circled in red.
    • Second, using the same PH-1 bit, you will remove the three 8mm screws hidden under the white wire. These screws are circled in orange.
    • Third, using the JIS-1 bit, remove the three 7mm screws on the circuit board.
    • After removing the circuit board, three more screws will be revealed.
    • Using the PH-1 bit, remove the last three 8mm screws, circled in green.
  4. Casio LK-170 Display Replacement: adım 4, 1 resimden 1.
    • Once all the screws have been removed, lift the component board and place it face down on the keys.
    • The component board is connected to the keyboard, so do not try to remove it.
  5. Casio LK-170 Display Replacement: adım 5, 1 resimden 1.
    • Flip over the component board to reveal the display that is currently connected to a green panel.
  6. Casio LK-170 Display Replacement: adım 6, 1 resimden 1.
    • Remove the display by carefully picking it up with your fingers from the green panel.
Sonuç
Samantha Baker
443 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-2, Banghart Winter 2017 Cal Poly, Team 13-2, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S13G2
3 Üyeler
5 adet Kılavuz yazıldı
1Rehber Yorum
Hey, where do you find a replacement lcd?
Albert istvab - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 787
