Ana içeriğe geç
Casio LK-170 Key Replacement
Neye ihtiyacın var
    1. Casio LK-170 Key Replacement, Key: adım 1, 3 resimden 1. Casio LK-170 Key Replacement, Key: adım 1, 3 resimden 2. Casio LK-170 Key Replacement, Key: adım 1, 3 resimden 3.
      • You will be removing 17 11mm screws with a JIS-1 screwdriver to detach the back of the keyboard from the front.
      • You will begin by removing 4 screws on each side of the piano, circled in red.
      • You will then remove the four screws that are a little hidden, circled in orange.
      • Next, remove the two screws in the middle of piano, as well as the three screws on the top of the piano, circled in yellow.
      FixBot'a Sor
      Yorum Ekle
    2. Casio LK-170 Key Replacement: adım 2, 2 resimden 1. Casio LK-170 Key Replacement: adım 2, 2 resimden 2.
      • After flipping the keyboard over to the front, carefully remove the the front panel from the back panel of the keyboard using your hands.
      • You should now see the screws holding the keys in place.
      • There are five 18mm screws per section of keys.
      • With a JIS-1 bit, unscrew the five screws in the section with the key you want to replace.
      FixBot'a Sor
      Yorum Ekle
    3. Casio LK-170 Key Replacement: adım 3, 2 resimden 1. Casio LK-170 Key Replacement: adım 3, 2 resimden 2.
      • You will be able to pick up the white keys with your hands and remove them.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Samantha Baker
443 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-2, Banghart Winter 2017 Cal Poly, Team 13-2, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S13G2
3 Üyeler
35 adet Kılavuz yazıldı
2Kılavuz Yorumları
This guide also works for the Casio LK-175.
The keys are in small groups and you will need to purchase the correct ones. Unfortunately, the ones I received from a seller did not match. I think he thought the part was compatible between my keyboard and the one he pulled them from. I very carefully tried super-gluing the key back onto it's section and so far so good (a few hours). Hopefully, the repair will hold.
Thank you for the guide Samantha.
Steve Ferrel - Yanıt Paylaş
Do you know if this exposes the circuit board(s)? I need to open my Casio LK175 to figure out why it's only working with batteries. I need to test the power adapter with a load...but the easiest way to do that would probably be measuring the voltage on the pins inside the board.
Thanks for posting this BTW. I saw so many screws on the bottom. I figured a lot of em were holding the keys. I was afraid to open it up, because I figured I'd mess it up. This is very helpful!
Heather Hodge - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 52
Her zaman: 2,987
