Ana içeriğe geç
Casio MH-10M Battery Replacement
Neye ihtiyacın var
  1. Casio MH-10M Battery Replacement, BATTERY: adım 1, 1 resimden 1.
    • This is the calculator in question.
    • Features a black and white dot matrix screen.
  2. Casio MH-10M Battery Replacement: adım 2, 2 resimden 1. Casio MH-10M Battery Replacement: adım 2, 2 resimden 2.
    • Turn the calculator over.
    • Locate the six screws on the rear of the device.
    • These are Philips #00 screws.
    • Keep the screws you remove in a safe place so they don't get lost.
  3. Casio MH-10M Battery Replacement: adım 3, 2 resimden 1. Casio MH-10M Battery Replacement: adım 3, 2 resimden 2.
    • Once the screws are removed, carefully lift the back panel off, lifting the top end first.
    • Place the panel to one side.
    • You can now see the battery.
  4. Casio MH-10M Battery Replacement: adım 4, 1 resimden 1.
    • Remove the battery
    • Lift it up from the right hand side to avoid damaging the spring.
    • You may find this easier to do by prying it out with the screwdriver.
  5. Casio MH-10M Battery Replacement: adım 5, 2 resimden 1. Casio MH-10M Battery Replacement: adım 5, 2 resimden 2.
    • Now you can insert the new battery
    • Ensure you place it in spring-first.
    • Congratulations! You have replaced the battery.
    • When reassembling, take care not to trap the red or black wires in the screws as this would sever them, making the calculator unusable.
    • Once reassembled, the calculator will be turned on. Turn it off to save battery by pressing Shift --> AC.
Sonuç
To reassemble your device, follow these instructions in reverse order, noting the two reassembly instructions in the last step.
26 farklı kişi bu kılavuzu tamamladı.
Sam
959 İtibar
1 Kılavuz yazıldı
3 Yorum
For some reason the two top screws made the calculator unstable, but removing them made it stable. Only occurred after removing the battery
Mida Galbraith - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 28
Her zaman: 49,236
